    Model created by SU 8 can't be open by SU 2013. HELP my work
    12 Posts 7 Posters 1.1k Views 7 Watching
    • J
      jerrywz68
      I have a model which was created by SU 8 Pro. This week I got SU update to 2013 version.
      Problem comes that I can't open this file (see attachment) from SU 2013, but SU 8 Pro can open that.
      Totally I have another two files in the same case.
      Can anyone let me know what part is wrong? I was planning to uninstall SU 8 Pro then use only SU 2013. But now I have to keep both of them.
      Any hint would be appreciated.
      created by SU 8 Pro but can't be opened in SU 2013
        That's a good spot Gus.
        • Gus RG
          Gus R
          Thanks. Might be an indication of a bug in SU 2013 since SU 8 can open it. Here's the crash details:
          Problem signature:
          Problem Event Name: APPCRASH
          Application Name: SketchUp.exe
          Application Version: 13.0.3689.0
          Application Timestamp: 51964b2d
          Fault Module Name: StackHash_b9d6
          Fault Module Version: 6.1.7601.17725
          Fault Module Timestamp: 4ec49b8f
          Exception Code: c0000374
          Exception Offset: 000ce6c3
          OS Version: 6.1.7601.2.1.0.256.48
          Locale ID: 1033
          Additional Information 1: b9d6
          Additional Information 2: b9d6161d49a531dbba8acddf4e877bbc
          Additional Information 3: d16a
          Additional Information 4: d16a6c6f9c7f85174618fc849b571870
          www.instagram.com/gusrobatto/
          www.facebook.com/gusrobatto
            Weirdly I got a Bugsplat trying to open once. From then on no splats but no opening
            • ely862meE
              ely862me
              How is this possible !!?? A texture to cut off sketchup's legs ?
              Elisei (sketchupper)
              Come and See EliseiDesign
              • Gus RG
                Gus R
                Same here. Went from a Bugsplat to an APPCRASH.
                • J
                  jerrywz68
                  OH MY! Thanks so much GUS! you saved my work. can't say more thanks on the solution. It works!
                  Hooray! my another two larger files (more than 25m in size) with same problems are back after I change material into pure white and re-save in SU8.
                  didn't expect at all the texture is the root.
                  Thanks again!
                  • Chris FullmerC
                    Thanks for posting this. I've submitted the model and the materials as a bug to be fixed.
                    It is the dark wood material that is actually causing the problem. Do you know anything about that jpg or how it was created?
                    Chris
                    All my Plugins I've written
                    • Alan FraserA
                      Alan Fraser
                      That wood texture is a nasty piece of work. Just trying to open it in an image editor was enough to freeze my laptop...had to do a forced reboot.
                      3D Figures
                      • Gus RG
                        Gus R
                        Was causing an APPCRASH on my SU Make (SU 2013). Went into the skp file in SU 8 and re-saved each of the material jpgs in PS. Re-opened in SU Make and all is well. Something is wrong with one of your material texture images. Here's the new file or you can try re-saving them yourself.
                        Edit Note: for some odd reason the wood material texture picked up the stainless steel material texture. Replaced skp file.
                        center bridge.skp
                        • Tyler MillerT
                          Tyler Miller
                          Hmmm... I don't like hearing that 2013 is having trouble opening a SU 8 file. In this case, however, I know why. SketchUp 2013 has an entirely new image handling library with all the latest format-specific libraries compiled in. In general, these updated libraries are much more strict about handling images (for security reasons). That said, I really wish we were handling the image rejecting properly and not crashing. We'll set up a unit test with this texture and see if we can get a fix in place.
                          Thanks,
                          Tyler
                          • J
                            jerrywz68
                            Chris
                            Yes, you are right. That dark wood texture pic was downloaded from Internet. Then I screetshot part of it to use as surface texture in my model.
