    2D export problem
    19 Posts 7 Posters 969 Views 7 Watching
    • hellnbakH Offline
      hellnbak
      I know this is undoubtedly so simple that even I should know it, but I don't.
      All I'm trying to do is export a 2D graphic. All it includes is a "stone" base and some fog (the models are there but hidden). But all I get is a white screen of nothing. It works ok when the models are visible.
      Please tell me what I'm doing wrong (and feel free to throw in a comment on how dumb I are)
      • U Offline
        unearthed
        I haven't used fog before in SU, but does the fog or fog-plane come all the way to the front of the image, i.e. the viewing plane - maybe the graphic export if just exporting the fog!
        Growplan - People ∩ Plants ∩ Place
        windows 7 64b, 4GB RAM, SU 8.0.16846
        Gimp, QGIS, Vectorworks 12, Bricscad 11
        • hellnbakH Offline
          hellnbak
          But when you export a graphic in SU, isn't it supposed to export what you can see? Shouldn't it capture anything that you can see on the screen?
          As for the fog, I turned it off and tried another export - it did capture the rock base. It makes absolutely no sense to me, none whatsoever (like so many other things in SU).
          I really need a new smilie, one pulling out his hair and beating his head bloody against a brick wall 😠 😠 😠
          • ely862meE Offline
            ely862me
            Could you take a printscreen with what exactly you see on your screen ? Or the model if alright ?
            Elisei (sketchupper)
            Come and See EliseiDesign
              Fog works fine for me, (in V7) models hidden or not! πŸ˜„
                I just did it on my Mac. I've never tried it on the PC but I could when I get home from work.
                Is the image of the stone applied as a texture to a face?
                What happens if you make a new SKP file with the stone texture and fog and no other geometry?
                • hellnbakH Offline
                  hellnbak
                  The image in my first post is a screen capture of what I see on my screen
                  Just a seamless texture applied to a large face
                  Ok, did that. Here's a screen capture of what I see
                  and here's what the 2D export looks like
                    What are your Style settings for sky/ground/background?
                    What is the 'stone texture' ?
                    A textured material applied onto a large face ?
                    An image ?
                    A watermark ?
                    I get good results with a textured-face on the ground and fog - everything you'd expect is in the exported jpg or png file...
                      Any chance you could post the SKP file?
                      What happens if you delete all the stuff you are hiding and then make the export?
                      • hellnbakH Offline
                        hellnbak
                        I've tried it with sky checked, ground checked, both checked, both unchecked, standing on one leg with a bowl of spaghetti on my head, nothing makes a difference in the export.
                        An image ?
                        A watermark ?
                        It's just a texture on a large face.
                        Well, that's what I'm using, a textured face on the ground. Tried exporting as both JPG and PNG, no difference.
                        SKP file attached
                        @dave r said:
                        "What happens if you delete all the stuff you are hiding and then make the export?
                        In my last post (with the blue fog) it was just the base and the fog, no models.
                        a.skp
                          Could it be a GPU issue? It worked fine for me. No setting changes. I opened the SKP and made an export.
                          • hellnbakH Offline
                            hellnbak
                            Don't see how it could be a GPU issue - while working on this problem I have exported a number of things, and the only one that gives me a problem is that stupid base with fog. I've exported the model, without the rock base, with fog, and it works fine. I've also tried replacing the texture with another, no difference.
                            I'm no expert, but seems to me that if my graphics card was gonna screw up it wouldn't be that selective. Of course I could be wrong (it had to happen someday πŸ˜‰)
                              Well, I guess I don't know what else it would be but it works fine for me.
                              • hellnbakH Offline
                                hellnbak
                                Well, it was only part of an experiment, and I can live without completing it. I almost never export 2D graphics, I use another program to do screen captures so unless it rears its ugly head again I'll just file it away in my X-Files.
                                (unless you wanna swap graphics cards)
                                Thanks to everyone for their efforts. Have a good one.
                                  Swapping cards probably wouldn't help you in this case.
                                  Seriously, you're just making screen shots? Wow! Screen shots would never be good enough for my needs.
                                  • ely862meE Offline
                                    ely862me
                                    What happens if the fog is off ?
                                    The model works fine for me too .
                                    OK I was able to replicate, please move the right cursor of the fog settings a lot more to the left, like 1 cm from the infinite sign, and it should export right !
                                    Apparently what you see on the screen is not exactly what you export, in our case, the fog is too close therefor you can't see a thing, just fog !
                                    • hellnbakH Offline
                                      hellnbak
                                      Well, my only needs are for showing models here on the forum. I use Fastone Capture.
                                      But it I do that then there's no point in using fog, it's all the way back to the horizon. Well, like I said, it was just part of something I was trying and I'm pretty sure the sun will come up tomorrow even if I don't solve it.
                                      My Kingdom for a normal problem!!
                                      • ely862meE Offline
                                        ely862me
                                        Do that and then export, and you'll see !
                                        • V Offline
                                          vojo
                                          I use export2d plugin for this kind of thing....one of the plugins that actually works quite well and makes backgrounds transparent in png. Good graphics outputs to date....so real pleased with it
