    2D export problem
    19 Posts 7 Posters 1.3k Views 7 Watching
      Any chance you could post the SKP file?
      What happens if you delete all the stuff you are hiding and then make the export?
      • hellnbakH
        hellnbak
        @tig said:
        What are your Style settings for sky/ground/background?
        I've tried it with sky checked, ground checked, both checked, both unchecked, standing on one leg with a bowl of spaghetti on my head, nothing makes a difference in the export.
        @tig said:
        What is the 'stone texture' ?
        A textured material applied onto a large face ?
        An image ?
        A watermark ?
        It's just a texture on a large face.
        @tig said:
        I get good results with a textured-face on the ground and fog - everything you'd expect is in the exported jpg or png file...
        Well, that's what I'm using, a textured face on the ground. Tried exporting as both JPG and PNG, no difference.
        SKP file attached
        @dave r said:
        "What happens if you delete all the stuff you are hiding and then make the export?
        In my last post (with the blue fog) it was just the base and the fog, no models.
        a.skp
          Could it be a GPU issue? It worked fine for me. No setting changes. I opened the SKP and made an export.
          • hellnbakH
            hellnbak
            Don't see how it could be a GPU issue - while working on this problem I have exported a number of things, and the only one that gives me a problem is that stupid base with fog. I've exported the model, without the rock base, with fog, and it works fine. I've also tried replacing the texture with another, no difference.
            I'm no expert, but seems to me that if my graphics card was gonna screw up it wouldn't be that selective. Of course I could be wrong (it had to happen someday πŸ˜‰)
              Well, I guess I don't know what else it would be but it works fine for me.
              • hellnbakH
                hellnbak
                Well, it was only part of an experiment, and I can live without completing it. I almost never export 2D graphics, I use another program to do screen captures so unless it rears its ugly head again I'll just file it away in my X-Files.
                (unless you wanna swap graphics cards)
                Thanks to everyone for their efforts. Have a good one.
                  Swapping cards probably wouldn't help you in this case.
                  Seriously, you're just making screen shots? Wow! Screen shots would never be good enough for my needs.
                  • ely862meE
                    ely862me
                    What happens if the fog is off ?
                    The model works fine for me too .
                    OK I was able to replicate, please move the right cursor of the fog settings a lot more to the left, like 1 cm from the infinite sign, and it should export right !
                    Apparently what you see on the screen is not exactly what you export, in our case, the fog is too close therefor you can't see a thing, just fog !
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                    • hellnbakH
                      hellnbak
                      Well, my only needs are for showing models here on the forum. I use Fastone Capture.
                      But it I do that then there's no point in using fog, it's all the way back to the horizon. Well, like I said, it was just part of something I was trying and I'm pretty sure the sun will come up tomorrow even if I don't solve it.
                      My Kingdom for a normal problem!!
                      • ely862meE
                        ely862me
                        Do that and then export, and you'll see !
                        • V
                          vojo
                          I use export2d plugin for this kind of thing....one of the plugins that actually works quite well and makes backgrounds transparent in png. Good graphics outputs to date....so real pleased with it
