    Fastest rotation?
    26 Posts 13 Posters 1.4k Views 13 Watching
    • cottyC Offline
      cotty
      Which would be the fastes way to rotate a group to a vertical position (see picture)?
      fastest_rotation.skp
      my SketchUp gallery
      • Wo3DanW Offline
        Wo3Dan
        A few steps but SU "thinks" for you:
        Add a (circular) face on top of the group (causing z-fighting but that doesn't matter)
        Right click this circular face > Align axes > Select group and circular face > Make component and! set 'Glue to: any'
        Reset global axes
        Select the new component and place it on ground plane > explode > delete circular face and its circumference.
        • cottyC Offline
          cotty
          Reset global axes
          Sounds like a smart solution 😉
          I think the step "place it on ground plane" should change the orientation of the group? This step doesn't work for me... 😕
          My solution so far:
          my SketchUp gallery
          • Wo3DanW Offline
            Wo3Dan
            (Even faster with a scene according to the groups local axes)
            Open the group > save a scene with its local axes saved (only these axes matter).
            Close group.
            Select saved scene > copy model to clipboard > reset axes to systems axes,
            Paste clipboard content to model again. It will be according to resetted (=systems) axes.
            • cottyC Offline
              cotty
              Close group.
              👍 very fast! 😲
              (I know I have to bookmark this because I will forget the exact steps in about 10 minutes 😎 )
              my SketchUp gallery
              • Wo3DanW Offline
                Wo3Dan
                @cotty said:
                I think the step "place it on ground plane" should change the orientation of the group? This step doesn't work for me... 😕 ...
                (I also thought of your solution, using one of the hidden lined on the side.)
                If you mean that new green and red of the rotated group should be aligned according to their previous projection on the ground plane, then you might be right, then my 'Glue to: any' component is only correct along blue. Then you need some extra marks for a final rotation about systems blue axis.
                Is this restriction included?
                • jeff hammondJ Offline
                  jeff hammond
                  use the move tool (at least in this particular instance)
                  [edit]
                  dotdotdot
                  • soloS Offline
                    solo
                    In theory one should be able to use 'smartdrop', as the bounding box is alignedb (but does not), this works in Vue by simply lifting it above flat surface and smart dropping it.
                    http://www.solos-art.com
                    • cottyC Offline
                      cotty
                      @wo3dan said:
                      ... is only correct along blue.
                      That was the only goal.
                      my SketchUp gallery
                        Align Tool 3D By Didier Bur ?
                        http://sketchuppluginreviews.com/wp-content/uploads/2010/05/align_tool_small.gif
                        Draw a Plane wished as second end Object
                        and now just 5 clicks 😄
                        • Wo3DanW Offline
                          Wo3Dan
                          Clever underestimated solution!
                          The tool lets you align to any current drawing axes with input 0, 90 etc. (degrees)
                          • cottyC Offline
                            cotty
                            👍 Didn't try this one but have to...
                            This will only work if the group was created before the rotations but if this is the case, it is very fast too.
                            Didn't work for me in this case.
                            my SketchUp gallery
                            • mitcorbM Offline
                              mitcorb
                              In case you folks didn't notice, Pilou has updated his post with a demo sequence.
                              • sdmitchS Offline
                                sdmitch
                                Using the Ruby Console
                                Sketchup.active_model.selection.first.transformation=Geom;;Transformation.new
                                http://sdmitch.blogspot.com/
                                  About the 3D Align tool by DIdier Bur above. 🤓
                                  And works also even the object is not a group or a component!
                                  So just a selection of something is sufficient! 😉
                                  • cottyC Offline
                                    cotty
                                    I will call it an expert solution 👍
                                    Did I say that I love this forum? ☀
                                    my SketchUp gallery
                                      As always, there's more than one way to do this. Some great options offered. Here's another one just for the heck of it.
                                      Assuming the cylinder is just loose geometry to start, make it a component, change it's axes so the bounding box is aligned to the geometry with the blue axis in the desired up direction. Bring in a copy of the component from the In Model Component library.
                                        Trogluddite
                                        Easy - just open the previous version of your project that you saved before going nuts making the geometry all wonky! 😆
                                          In this particular start position Sketchyphics can also works! 💚
                                          • Jean LemireJ Offline
                                            Jean Lemire
                                            Hi folks.
                                            If you want to practice with native tools, it takes only two quickly done rotations.
                                            Don't forget this trick from the help:
                                            http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94897
                                            See this SU file for ideas:
                                            fastest_rotation - V6 - JL.skp
                                            • 1 / 2
