    A two-part material question
    26 Posts 5 Posters 1.2k Views 5 Watching
    • hellnbakH Offline
      hellnbak
      Ok, I did the whole kmz export thing and have a folder showing all the textures in my model. Here's the problem
      The folder shows that there are 531 materials in my model. My Materials Window shows only 314 materials. Of those 531 materials, over 300 of them are very tiny (under 1kb) textures, so tiny I can't even tell what they are. Here are some of them --
      None of these tiny materials show up in my Materials Window. So what's going on?
      The second part of my question concerns problems with deleting materials from my Materials Window. Sometimes it works, but sometimes I simply cannot delete a material. I click on it, then right click for my options, but then it hangs for awhile, my screen flashes, and nothing happens. I know I saw a post here not too long ago about this, and it seems like it might have had a useable solution, but of course I cannot find it now.
      Any help would be greatly appreciated
      • cottyC Offline
        cotty
        Does a triangulation before the export reduce the tiny textures?
        my SketchUp gallery
        • cottyC Offline
          cotty
          I had this video in mind...
          my SketchUp gallery
            I am pretty sure this is the solution. When there is a distorted material in SU, the collada exporter "explodes" that material into as many pieces as facets you have applied it to. Triangulation will prevent this.
            As for the material browser issue, this might be the other topic but I see no solution for it (nor I have ever experienced it before so I am stumped)
              Image elements also contains textures.
              • hellnbakH Offline
                hellnbak
                I'm trying your triangulation theory, but it has been triangulating for almost 30 minutes. Is this normal or is it hung up?
                  Depends on the density of the mesh and if SU needs to triangulate Ngons.
                  SU is basically crunching the numbers to cut up your mesh into tris and this can take time. Leave it think. It will do it but it might just take some time.
                  • hellnbakH Offline
                    hellnbak
                    I waited over two hours, even tho the Task Manager showed SU as not responding, on the off-chance that it might actually be doing something useful. Then I shut it down. I know I didn't have that many non-triangulated faces in there.
                      Can you email me the file?
                      richob[at]sketchucation.com
                      • hellnbakH Offline
                        hellnbak
                        It's over 45mb.
                        What I'll probably try next is to copy parts of it into a new instance of SU, then check each one to see if that part includes all the tiny textures. If and when I find the culprit I'll try triangulating it and see if that solved the problem.
                        Sound worthwhile?
                        (of course doing this will probably bring into play the problems associated with copying and pasting, but what you gonna do? πŸ˜„
                          use my color ngon plugin to colour a face the has more than # edges.
                          then select these faces by right clicking the texture in the materials browser
                          then triangulate this selection
                          do this in chunks
                          • hellnbakH Offline
                            hellnbak
                            GOT IT!!
                            First I deleted anything that was not mine, namely the plants and tree. That got rid of all the tiny green textures. The only ones left seemed to be red, about the color of the Coke machine. Deleted that, and no more tiny textures. Down to just 137 textures now.
                            Now I'll try copying and pasting it and triangulating it, see if that works.
                            (should have known better than to download something from the Warehouse. Guess I'll have to learn to make my own plants and trees. Great! one more thing to learn πŸ˜’ )
                              please don't start making other stuff...every you do turns to gold πŸ˜‰
                              • hellnbakH Offline
                                hellnbak
                                Well, triangulation didn't seem to agree with my Coke machine --
                                Don't know why this model should cause a problem, just used normal methods.
                                • hellnbakH Offline
                                  hellnbak
                                  Actually another color is more accurate...sort of brownish πŸ˜†
                                    Can you send me the Coke machine and I have a blast?
                                    • hellnbakH Offline
                                      hellnbak
                                      You want the triangulated or non-triangulated version?
                                        non-tri with textures not f$&ked up
                                        • hellnbakH Offline
                                          hellnbak
                                          Oh, I get it now....."Coke" machine πŸ˜†
                                          • hellnbakH Offline
                                            hellnbak
                                            Ok, here it is. Keep in mind that it is just "set dressing" and not meant to stand up to close scrutiny as a stand-alone model.
                                            coke machine.skp
                                            • 1 / 2
