    A two-part material question
    26 Posts 5 Posters 1.9k Views 5 Watching
    • cottyC
      cotty
      Does a triangulation before the export reduce the tiny textures?
      my SketchUp gallery
      • cottyC
        cotty
        I had this video in mind...
        my SketchUp gallery
        • GaieusG
          I am pretty sure this is the solution. When there is a distorted material in SU, the collada exporter "explodes" that material into as many pieces as facets you have applied it to. Triangulation will prevent this.
          As for the material browser issue, this might be the other topic but I see no solution for it (nor I have ever experienced it before so I am stumped)
            Image elements also contains textures.
            • hellnbakH
              hellnbak
              I'm trying your triangulation theory, but it has been triangulating for almost 30 minutes. Is this normal or is it hung up?
                Depends on the density of the mesh and if SU needs to triangulate Ngons.
                SU is basically crunching the numbers to cut up your mesh into tris and this can take time. Leave it think. It will do it but it might just take some time.
                • hellnbakH
                  hellnbak
                  I waited over two hours, even tho the Task Manager showed SU as not responding, on the off-chance that it might actually be doing something useful. Then I shut it down. I know I didn't have that many non-triangulated faces in there.
                    Can you email me the file?
                    richob[at]sketchucation.com
                    • hellnbakH
                      hellnbak
                      It's over 45mb.
                      What I'll probably try next is to copy parts of it into a new instance of SU, then check each one to see if that part includes all the tiny textures. If and when I find the culprit I'll try triangulating it and see if that solved the problem.
                      Sound worthwhile?
                      (of course doing this will probably bring into play the problems associated with copying and pasting, but what you gonna do? πŸ˜„
                        use my color ngon plugin to colour a face the has more than # edges.
                        then select these faces by right clicking the texture in the materials browser
                        then triangulate this selection
                        do this in chunks
                        • hellnbakH
                          hellnbak
                          GOT IT!!
                          First I deleted anything that was not mine, namely the plants and tree. That got rid of all the tiny green textures. The only ones left seemed to be red, about the color of the Coke machine. Deleted that, and no more tiny textures. Down to just 137 textures now.
                          Now I'll try copying and pasting it and triangulating it, see if that works.
                          (should have known better than to download something from the Warehouse. Guess I'll have to learn to make my own plants and trees. Great! one more thing to learn πŸ˜’ )
                            please don't start making other stuff...every you do turns to gold πŸ˜‰
                            • hellnbakH
                              hellnbak
                              Well, triangulation didn't seem to agree with my Coke machine --
                              Don't know why this model should cause a problem, just used normal methods.
                              • hellnbakH
                                hellnbak
                                Actually another color is more accurate...sort of brownish πŸ˜†
                                  Can you send me the Coke machine and I have a blast?
                                  • hellnbakH
                                    hellnbak
                                    You want the triangulated or non-triangulated version?
                                      non-tri with textures not f$&ked up
                                      • hellnbakH
                                        hellnbak
                                        Oh, I get it now....."Coke" machine πŸ˜†
                                        • hellnbakH
                                          hellnbak
                                          Ok, here it is. Keep in mind that it is just "set dressing" and not meant to stand up to close scrutiny as a stand-alone model.
                                          coke machine.skp
                                            This exported as one texture as a .kmz for me
                                            coke machine.skp
