    A two-part material question
    26 Posts 5 Posters 1.7k Views 5 Watching
      Depends on the density of the mesh and if SU needs to triangulate Ngons.
      SU is basically crunching the numbers to cut up your mesh into tris and this can take time. Leave it think. It will do it but it might just take some time.
      • hellnbakH
        hellnbak
        I waited over two hours, even tho the Task Manager showed SU as not responding, on the off-chance that it might actually be doing something useful. Then I shut it down. I know I didn't have that many non-triangulated faces in there.
          Can you email me the file?
          richob[at]sketchucation.com
          • hellnbakH
            hellnbak
            It's over 45mb.
            What I'll probably try next is to copy parts of it into a new instance of SU, then check each one to see if that part includes all the tiny textures. If and when I find the culprit I'll try triangulating it and see if that solved the problem.
            Sound worthwhile?
            (of course doing this will probably bring into play the problems associated with copying and pasting, but what you gonna do? πŸ˜„
              use my color ngon plugin to colour a face the has more than # edges.
              then select these faces by right clicking the texture in the materials browser
              then triangulate this selection
              do this in chunks
              • hellnbakH
                hellnbak
                GOT IT!!
                First I deleted anything that was not mine, namely the plants and tree. That got rid of all the tiny green textures. The only ones left seemed to be red, about the color of the Coke machine. Deleted that, and no more tiny textures. Down to just 137 textures now.
                Now I'll try copying and pasting it and triangulating it, see if that works.
                (should have known better than to download something from the Warehouse. Guess I'll have to learn to make my own plants and trees. Great! one more thing to learn πŸ˜’ )
                  please don't start making other stuff...every you do turns to gold πŸ˜‰
                  • hellnbakH
                    hellnbak
                    Well, triangulation didn't seem to agree with my Coke machine --
                    Don't know why this model should cause a problem, just used normal methods.
                    • hellnbakH
                      hellnbak
                      Actually another color is more accurate...sort of brownish πŸ˜†
                        Can you send me the Coke machine and I have a blast?
                        • hellnbakH
                          hellnbak
                          You want the triangulated or non-triangulated version?
                            non-tri with textures not f$&ked up
                            • hellnbakH
                              hellnbak
                              Oh, I get it now....."Coke" machine πŸ˜†
                              • hellnbakH
                                hellnbak
                                Ok, here it is. Keep in mind that it is just "set dressing" and not meant to stand up to close scrutiny as a stand-alone model.
                                coke machine.skp
                                  This exported as one texture as a .kmz for me
                                  coke machine.skp
                                  • hellnbakH
                                    hellnbak
                                    [attachment=0:1oucbrdy]<!-- ia0 -->coke machine.skp<!-- ia0 -->[/attachment:1oucbrdy]
                                    Well, I didn't export the Coke machine to check the textures, I just deleted it from my gas station model and then exported it, and the small textures went away. Does that give you any insight as to what's going on?
                                      so what exactly is yor problem now?
                                      your original post was 'why do I have so many textures?' Then 'why is it taking ages to triangulate?'
                                      So I took those to mean your were trying to export this as kmz to see if you get lots of textures?
                                      • hellnbakH
                                        hellnbak
                                        Well, I went thru everything again, and discovered that I had made a major mistake. When I thought I had just deleted the Coke machine, I had in fact also deleted the red trashcan. When I export just the trashcan, I get all the tiny textures. 😳 😳
                                        My apologies, I'm tired, I'm cold, and I need coffee.
                                          no worries, can i have the can to do the can can?
                                          • hellnbakH
                                            hellnbak
                                            πŸ˜†
