    Irregular Surface to Solid Group
    22 Posts 9 Posters 2.7k Views 9 Watching
    • T
      twestover
      I've been trying for some time to find a way to create a solid group with vertical sides, a horizontal bottom, and an irregular triangulated top.
      I import a series of XYZ points and then triangulate the surface. I'd like to turn that into a solid so that I can then use the SU Pro solid tools to manipulate it.
      In the past, I've drawn vertical lines down from each vertex on the perimeter, and then manually connected each one, taking the time to go "inside" the solid and erase any internal faces that were generated. This was reasonable for small models, but now the number of perimeter vertices is high (>500) and this seems like a unnecessary effort.
      I've tried the "projection extension" toolbar using "extrude multiple faces along Z", but that created many internal faces that would have to be removed. What I'm looking for is similar to adding a skirt to GE terrain, but doesn't work with just a collection of faces.
      Any suggestions?
      • TIGT
        I think sdmitch already did this... http://sketchucation.com/forums/viewtopic.php?p=359903#p359903
        Please learn to use the SCF-forum/your-browser search/find functions thoroughly...
        More often that not it's been done before... or something pretty much like it...
        šŸ˜‰
          Fredo is cooking a plug about Terrain don't know if that can help you!
          • T
            twestover
            Thanks TIG.
            I have been searching the SCF, other forums, and plugin libraries fairly extensively, and sdmitch's solution is what I refer to the in the last paragraph on adding the skirt. Since my surface is not Google Earth terrain, his plugin would not handle the surface.
            I've been using search terms like this post subject or "push pull multiple faces" or "extrude multiple surfaces". I've found answers for multiple faces that are separate, but not if they are joined in a triangulation like mine. If you have any suggestions for SketchUp lingo I'm missing, I would be grateful.
            • Chris FullmerC
              http://sketchucation.com/forums/viewtopic.php?f=15&t=44282&start=60
              Keep your eyes open for fredo's Topo Shaper. Looks like part of its functionality will do what you're looking for.
              Chris
              All my Plugins I've written
                There was a plugin who permit to scult or modify a volume "like zbrush"
                by BTL
                bulge and push (shift to reverse both)
                •smooth
                •smudge
                •grab (works like a soft move at 100%)
                •…and a planar lock feature.
                http://forum.zbrush.fr/index.php?action=dlattach;topic=4835.0;attach=8867 ;image
                Artisan can also make that
                • Chris FullmerC
                  d'oh, I see you already posted a link to fredo's script Frenchy, sorry for the double post!
                  • T
                    twestover
                    Thank you both. I'll be watching for that one.
                    • sdmitchS
                      sdmitch
                      Tom, I have sent you a version, by PM, that should work with any grouped terrain mesh.
                      http://sdmitch.blogspot.com/
                      • jeff hammondJ
                        jeff hammond
                        TIG's extrude_edges_by_vector_to_object
                        http://sketchucation.com/forums/viewtopic.php?t=37515
                        recurve the perimeter edges for easy selection then go...
                        cleanup coplanar edges if desired..
                        dotdotdot
                        • jeff hammondJ
                          jeff hammond
                          also, vector push pull
                          (part of joint push pull: http://sketchucation.com/forums/viewtopic.php?t=6708)
                          you can do it with selecting the surface.. use <tab> for options then change to thickening..
                          intersect with plane for flat bottom..
                          dotdotdot
                          • GaieusG
                            You can also use drape and Fredo's Curviloft to create that skirt.
                            First drape the perimeters of your terrain onto a flat plane:
                            Next select the topo above and the draped shape below
                            Set the curviloft settings
                            After some clean-up (and moving the ungrouped top and bottom surfaces inside the curvilofted group) you get a nice solid.
                            True that my topo has a rectangular outline here but it should work with any shape...
                              Another cool solution! šŸ’š
                              The Joint Push Pull by Fredo 6
                              Color by the fabulous Color by Z by Chris Fullmer!
                              • pbacotP
                                Using solid tools for terrain modification. Never thought of that.... Interesting idea.
                                • T
                                  twestover
                                  Thank you all for the creative solutions! sdmitch's solution for any mesh worked great. These others have me loading up on additional plugins.
                                    Can you share the Sdmitch solution ?
                                    • Jean LemireJ
                                      Jean Lemire
                                      Hi folks.
                                      I did that a while ago for someone who asked the same question. See this SU file for ideas.
                                      Box under topo.skp
                                      • sdmitchS
                                        sdmitch
                                        The version on my blog does not require a GE terrain patch.
                                          Alas the Drape method (Thx Jean for the V6 šŸ˜‰ don't work at any time without very big cleaning! 😮
                                          JPP vector yes! ā˜€
                                          no_drap.skp
                                          • Jean LemireJ
                                            Jean Lemire
                                            Hi Pilou, hi folks.
                                            Try smoothing all the surface before draping to get only the contour instead of zillions of edges and faces.
                                            Just ideas.
                                            • 1 / 2
