    Irregular Surface to Solid Group
    22 Posts 9 Posters 2.7k Views 9 Watching
    • jeff hammondJ
      also, vector push pull
      (part of joint push pull: http://sketchucation.com/forums/viewtopic.php?t=6708)
      you can do it with selecting the surface.. use <tab> for options then change to thickening..
      intersect with plane for flat bottom..
      • GaieusG
        You can also use drape and Fredo's Curviloft to create that skirt.
        First drape the perimeters of your terrain onto a flat plane:
        Next select the topo above and the draped shape below
        Set the curviloft settings
        After some clean-up (and moving the ungrouped top and bottom surfaces inside the curvilofted group) you get a nice solid.
        True that my topo has a rectangular outline here but it should work with any shape...
          Another cool solution! ๐Ÿ’š
          The Joint Push Pull by Fredo 6
          Color by the fabulous Color by Z by Chris Fullmer!
          • pbacotP
            Using solid tools for terrain modification. Never thought of that.... Interesting idea.
            • T
              twestover
              Thank you all for the creative solutions! sdmitch's solution for any mesh worked great. These others have me loading up on additional plugins.
                Can you share the Sdmitch solution ?
                • Jean LemireJ
                  Jean Lemire
                  Hi folks.
                  I did that a while ago for someone who asked the same question. See this SU file for ideas.
                  Box under topo.skp
                  • sdmitchS
                    sdmitch
                    The version on my blog does not require a GE terrain patch.
                    http://sdmitch.blogspot.com/
                      Alas the Drape method (Thx Jean for the V6 ๐Ÿ˜‰ don't work at any time without very big cleaning! ๐Ÿ˜ฎ
                      JPP vector yes! โ˜€
                      no_drap.skp
                      • Jean LemireJ
                        Jean Lemire
                        Hi Pilou, hi folks.
                        Try smoothing all the surface before draping to get only the contour instead of zillions of edges and faces.
                        Just ideas.
                          Zillions ? ๐Ÿ˜„
                          I have 323 entities for the surface and less 80 segments as perimeter! ๐Ÿ˜ฒ
                          But Ok with Smooth at the maximum I obtain just one edge alone to close by hand ๐Ÿ˜‰
                          (not a big deal - the only difficulty is to find it! )
                          But this will be the same with a bigger surface more sinuous on the edges?
                          Here I have 2 big straigth lines edges with only 2 arc circles toward inner!
                          If I have 100 edges to close ? ๐Ÿ˜‰
                          And after with your method i must make several intersections (just one Push Pull for natural intersection is not sufficient (but not a big deal again ๐Ÿ˜„
                          • pbacotP
                            Another way.
                            I also thought there was no need to act on all the faces. Here is a complex model. Skirt made with TIG's extrude-edges-by-vector-to-object EEbyVTO. Only problem I have trouble getting all the edges to go all the way to the face (I wonder if there's a lack of technique on my part). So I then pull the face up and intersect with model. (This method seems to choke on an even more complex model, but it might work.)
