    Deep nest
    27 Posts 12 Posters 7.7k Views 12 Watching
    • kachuppK
      kachupp
      Looking for a plugin that has a; ONE click exit from a deeply nested component preferably “right click context menu” Any tool exist?
        Have you tried using the Outliner?
        • kachuppK
          kachupp
          Never thought of using it.. it works. I'd still prefer right click exit 👍
          • J
            Jim
            Paste this into a file with the .rb extension in your plugins folder.
            UI.add_context_menu_handler {|menu|
              menu.add_item("Close All Contexts") {
                Sketchup.active_model.selection.clear
                while (Sketchup.active_model.close_active); end
            • kachuppK
              kachupp
              Perfect Jim thank you very much
              • irwanwrI
                irwanwr
                [Plugin] Deep Nested Escape? 😛
                • halroachH
                  halroach
                  Nice!
                  I am unable to assign a keyboard shortcut to it. How can I do it?
                  FlexTools - Super Quick Windows, Doors, Slats...
                  • massimoM
                    massimo Moderator
                    You'll find it in the context menu: right click-->Close All Contexts
                      Since it is in the Context menu, you need to have something selected such that there'd be a Context menu entry for the plugin. Open a component or group within a nest and select an edge or face. It'll then be available for setting the shortcut.
                      • halroachH
                        halroach
                        [attachment=0:32nirxzw]<!-- ia0 -->close.PNG<!-- ia0 -->[/attachment:32nirxzw]
                        Right!! thanks!!!
                        Excellent!!! 👍 👍
                        • massimoM
                          massimo Moderator
                          Not so easy I'm afraid, but i might be wrong. It will work only depending on what you have selected when you assigned the shortcut and not in any situation and at any "level" of selection like the "normal" right click does.
                            Massimo, you're right. However the plugin isn't available to select from the Function list unless an entity within a component is selected. It doesn't have to be a face within an inner component. It could be a component that is selected. Unless an entity is selected, though, the keyboard shortcut won't work. Weird.
                            • Bob JamesB
                              Bob James
                              Called it BackOut.rb, assigned a shortcut to it, added it to a key on my P.I. Engineering x-keys keyboard and now I can back out from within any group/component with one key. Sure beats pecking at the Escape key 😄
                              Thank you very much 👍
                              • J
                                Jim
                                You're welcome.
                                I will be adding 2 commands to Custom Toolbars named "CloseActive" and "CloseAllActive" for those who like toolbar buttons.
                                • J
                                  Jim
                                  Bob, I could put "BackOut.rb" in the Plugin Store, if that would be alright with you.
                                  Although I wonder if it's worth it for what is practically a one-liner; but I suppose code size isn't always related to usefulness.
                                  • K
                                    kaas
                                    Thanks a lot! Those few lines of code make working with more complex object trees much easier.
                                    • tt_suT
                                      tt_su
                                      The Outliner will let you jump directly in and out of the model hierarchy.
                                      • K
                                        kaas
                                        I know, I use it all the time but using a keypress is a bit more quick than moving the pen to the outliner and back again.
                                        • Bob JamesB
                                          Bob James
                                          It's your plugin, all I did was give it a name 😄
                                          This one is worth it
                                          BackOut.rb
                                          • KrisidiousK
                                            Krisidious
                                            looked for this in the plugin store... didn't find it. needs to be there. doesn't seem to work in 2015?
                                            By: Kristoff Rand
                                            • 1 / 2
