    Deep nest
    27 Posts 12 Posters 7.4k Views 12 Watching
    • kachuppK Offline
      kachupp
      Perfect Jim thank you very much
      • irwanwrI Offline
        irwanwr
        [Plugin] Deep Nested Escape? 😛
        • halroachH Offline
          halroach
          Nice!
          I am unable to assign a keyboard shortcut to it. How can I do it?
          FlexTools - Super Quick Windows, Doors, Slats...
          • massimoM Offline
            massimo Moderator
            You'll find it in the context menu: right click-->Close All Contexts
              Since it is in the Context menu, you need to have something selected such that there'd be a Context menu entry for the plugin. Open a component or group within a nest and select an edge or face. It'll then be available for setting the shortcut.
              • halroachH Offline
                halroach
                [attachment=0:32nirxzw]<!-- ia0 -->close.PNG<!-- ia0 -->[/attachment:32nirxzw]
                Right!! thanks!!!
                Excellent!!! 👍 👍
                • massimoM Offline
                  massimo Moderator
                  Not so easy I'm afraid, but i might be wrong. It will work only depending on what you have selected when you assigned the shortcut and not in any situation and at any "level" of selection like the "normal" right click does.
                    Massimo, you're right. However the plugin isn't available to select from the Function list unless an entity within a component is selected. It doesn't have to be a face within an inner component. It could be a component that is selected. Unless an entity is selected, though, the keyboard shortcut won't work. Weird.
                    • Bob JamesB Offline
                      Bob James
                      @jim said:
                      Paste this into a file with the .rb extension in your plugins folder.
                      > UI.add_context_menu_handler {|menu|
                      >   menu.add_item("Close All Contexts") {
                      >     Sketchup.active_model.selection.clear
                      >     while (Sketchup.active_model.close_active); end
                      Called it BackOut.rb, assigned a shortcut to it, added it to a key on my P.I. Engineering x-keys keyboard and now I can back out from within any group/component with one key. Sure beats pecking at the Escape key 😄
                      Thank you very much 👍
                        Jim
                        You're welcome.
                        I will be adding 2 commands to Custom Toolbars named "CloseActive" and "CloseAllActive" for those who like toolbar buttons.
                          Jim
                          Bob, I could put "BackOut.rb" in the Plugin Store, if that would be alright with you.
                          Although I wonder if it's worth it for what is practically a one-liner; but I suppose code size isn't always related to usefulness.
                            kaas
                            Thanks a lot! Those few lines of code make working with more complex object trees much easier.
                            • tt_suT Offline
                              tt_su
                              The Outliner will let you jump directly in and out of the model hierarchy.
                                kaas
                                I know, I use it all the time but using a keypress is a bit more quick than moving the pen to the outliner and back again.
                                  Bob James
                                  It's your plugin, all I did was give it a name 😄
                                  This one is worth it
                                  BackOut.rb
                                  • KrisidiousK Offline
                                    Krisidious
                                    looked for this in the plugin store... didn't find it. needs to be there. doesn't seem to work in 2015?
                                    By: Kristoff Rand
                                    • BoxB Offline
                                      Works fine for me in 2015
                                        It does for me, too.
                                          Krisidious
                                          Hmmm...
                                          By: Kristoff Rand
                                            Krisidious
                                            Did you save the rb or make one yourself?
                                            That was it... I made the rb last time and this time I downloaded it. it's called backout now instead of close all contexts as I'm used to.
                                            Thanks guys.
                                            By: Kristoff Rand
