    Deep nest
    27 Posts 12 Posters 7.4k Views 12 Watching
    • kachuppK Offline
      kachupp
      @dave r said:
      Have you tried using the Outliner?
      Never thought of using it.. it works. I'd still prefer right click exit 👍
        Jim
        Paste this into a file with the .rb extension in your plugins folder.
        UI.add_context_menu_handler {|menu|
          menu.add_item("Close All Contexts") {
            Sketchup.active_model.selection.clear
            while (Sketchup.active_model.close_active); end
        • kachuppK Offline
          kachupp
          Perfect Jim thank you very much
          • irwanwrI Offline
            irwanwr
            [Plugin] Deep Nested Escape? 😛
            • halroachH Offline
              halroach
              Nice!
              I am unable to assign a keyboard shortcut to it. How can I do it?
              FlexTools - Super Quick Windows, Doors, Slats...
              • massimoM Offline
                massimo Moderator
                You'll find it in the context menu: right click-->Close All Contexts
                  Since it is in the Context menu, you need to have something selected such that there'd be a Context menu entry for the plugin. Open a component or group within a nest and select an edge or face. It'll then be available for setting the shortcut.
                  • halroachH Offline
                    halroach
                    [attachment=0:32nirxzw]<!-- ia0 -->close.PNG<!-- ia0 -->[/attachment:32nirxzw]
                    Right!! thanks!!!
                    Excellent!!! 👍 👍
                    • massimoM Offline
                      massimo Moderator
                      Not so easy I'm afraid, but i might be wrong. It will work only depending on what you have selected when you assigned the shortcut and not in any situation and at any "level" of selection like the "normal" right click does.
                        Massimo, you're right. However the plugin isn't available to select from the Function list unless an entity within a component is selected. It doesn't have to be a face within an inner component. It could be a component that is selected. Unless an entity is selected, though, the keyboard shortcut won't work. Weird.
                        • Bob JamesB Offline
                          Bob James
                          Called it BackOut.rb, assigned a shortcut to it, added it to a key on my P.I. Engineering x-keys keyboard and now I can back out from within any group/component with one key. Sure beats pecking at the Escape key 😄
                          Thank you very much 👍
                            Jim
                            You're welcome.
                            I will be adding 2 commands to Custom Toolbars named "CloseActive" and "CloseAllActive" for those who like toolbar buttons.
                              Jim
                              Bob, I could put "BackOut.rb" in the Plugin Store, if that would be alright with you.
                              Although I wonder if it's worth it for what is practically a one-liner; but I suppose code size isn't always related to usefulness.
                                kaas
                                Thanks a lot! Those few lines of code make working with more complex object trees much easier.
                                • tt_suT Offline
                                  tt_su
                                  The Outliner will let you jump directly in and out of the model hierarchy.
                                    kaas
                                    I know, I use it all the time but using a keypress is a bit more quick than moving the pen to the outliner and back again.
                                      Bob James
                                      It's your plugin, all I did was give it a name 😄
                                      This one is worth it
                                      BackOut.rb
                                      • KrisidiousK Offline
                                        Krisidious
                                        looked for this in the plugin store... didn't find it. needs to be there. doesn't seem to work in 2015?
                                        By: Kristoff Rand
                                        • BoxB Offline
                                          Works fine for me in 2015
                                            It does for me, too.
