    Something like "follow me" tool is needed
    29 Posts 7 Posters 4.2k Views 7 Watching
      banan666
      Hi, I just start work with sketchup. I watched a lot of video on YT about it. Now I want to create model of mdf panel, then transform it to gcodes and make it on cnc machine. I made simple sketch of a panel, it looks like that:
      http://s1.pokazywarka.pl/bigImages/1692991/5940739.jpg
      and I want to make 5 mm cavity in the material fallow the every line, like that:
      http://s1.pokazywarka.pl/i/1692991/198890/post5.jpg
      or like that:
      http://s1.pokazywarka.pl/i/1692991/714272/post6.jpg
      I could use "fallow me tool", but I need to make every single line separetly.
      The final panel should look like one of this three samples:
      http://s1.pokazywarka.pl/i/1692991/685729/post4.jpg
      http://s1.pokazywarka.pl/i/1692991/123255/post2.jpg
      http://s1.pokazywarka.pl/i/1692991/499647/post3.jpg
      Of course I could choose few diferent shape of the pocket, it doesnt matter actually, the problem is have to make it at once. Could any one help me?
      • cottyC Offline
        cotty
        You can use Multiple Offset for this...
        my SketchUp gallery
          banan666
          I try to use tis multiple offset, but it doesnt work fine for me.
          Firt I select the lines, but when I make a group of them, then I couldn`t use the "multiple offset". So I select only the top lines, use the "multiple offset".
          http://s1.pokazywarka.pl/bigImages/1694076/5945251.jpg
          Then I select whole sketch, use Explode curve.
          http://s1.pokazywarka.pl/bigImages/1694076/5945248.jpg
          Then select only the midle lines and use "move tool" and it looks like that.
          http://s1.pokazywarka.pl/bigImages/1694076/5945245.jpg
          Could You explain me step by step what to do??
            You must start with a simple plan, not a volume!!!
            You can find a mutiple face offset here by R.Knowles
            Another one by Remus
            Lattice-izer by Tig can help for some thing
            And a more complex Offset multiples by Sdmitch
            • cottyC Offline
              cotty
              The group of lines is only used to make a fast selection of the lines after using multiple offset and has nothing to do with the offset process. For this, you select all faces and use the plugin.
              my SketchUp gallery
                Here a simple different method ๐Ÿ˜‰
                choco1.skp
                  Ok I believe now a more easy method! โ˜€
                  (because the Cotty method don't work for me : all corners are disturbed ! ๐Ÿ˜ฎ )
                  (maybe the V6...)
                  Draw a rectangle
                  Trace your lines with the Zorro 2 by Whaat
                  ( more easy but you can draw lines normally ๐Ÿ˜‰
                  Select all
                  Multi Faces Offset (with plugins above)
                  Invert Selection by TIG so faces are selected ! The trick ! ๐Ÿ’ญ
                  Move UP Faces + Alt
                  That's all ๐Ÿ˜„
                    banan666
                    Ok guys, finally I made it ๐Ÿ˜„
                    http://s1.pokazywarka.pl/bigImages/1694527/5946503.jpg
                    But how could I make other shape, for example circle, or square down there??
                    http://s1.pokazywarka.pl/bigImages/1694531/5946506.jpg
                      Maybe just draw tubes or long boxes ๐Ÿ˜„
                      A simple Push pull can do that!
                      And make intersections with a big box!
                      Lines2tubes by Didier Bur can help you ๐Ÿ˜‰
                      With it you can make from 3 sides to 100 section polygons !
                      Just make lines bigger than the box for easy intersection!
                      Seems each cylinder is a volume you can Make boolean operation with the pro version
                      but you have not ๐Ÿ˜„
                      so intersection will be a solution
                        banan666
                        I made a try of the "line2tube" plugin and it doesnt work for me with "boolean OSCoolean".
                        Everything is ok with straight lines, but when I make some curves, then use "line2tube", and then try to use "boolean", nothing hapends. It only say: OSCoolean is processing....Nothing else.
                        http://s1.pokazywarka.pl/bigImages/1704567/5982803.jpg
                          Ps Anf for your beginning post I know a ruby coder who is making a ruby one so be patient ๐Ÿ˜„
                            Better if you save also the skp file ๐Ÿ˜‰
                            Like that I have not to modelize something!
                            Seems works for me! โ˜€
                            I make the line to tube
                            Kill the line generator
                            Explode the tube volume
                            Group it
                            and all works fine ๐Ÿ˜„
                            tube1.skp
                              banan666
                              I dont know why it doesnt work for me, please check my sketch.
                              Untitled.skp
                                Ok I have found the problem ๐Ÿ˜‰
                                When you click your object (the curvated volume) and call the Info box model info..., that is not a "solid"!!!
                                so that can't work!
                                So make it as solid and all will work as a charm!
                                explode all, kill the middle ring, explode curve, kill the curve generator, make a group
                                = you must have a clean solid!
                                all works fine โ˜€
                                tube2.skp
                                  Well spotted Pilou !
                                  A 'solid' is necessary for doing boolean operations.
                                  A solid contains only faces and edges.
                                  Every edge must have two faces.
                                  No fewer and no more.
                                  The 'tube' group as made still has the curve curve snaking up its center - edges with NO faces.
                                  It also seem to have a central disk partition - edges with three faces !
                                  I prefer an even simpler way of fixing this.
                                  Edit the group, Xray mode and then pick the internal curves edges and Delete key.
                                  Similarly with the 'disk'.
                                  Now 'Entity Info' should report the selected group as being a 'solid'...
                                    ...and an infinite new world is opening for you! ๐Ÿ˜„
                                      banan666
                                      Thx guys for Your advices, it work with low angle lines. But it start to get problems when the curve its much biger, because when I use Arc to make a shepe, next line2tube I got a lot of gapes in the joints. I dont Know how to fix them, so I made second try with other shape maker, I used Cornu Spline from Curve Maker, the line2tubes, clean all internal curves and 'disks', and 'Entity Info' report me that the selected group as being not a 'solid', just group 1 in model...
                                      http://s1.pokazywarka.pl/bigImages/1705709/5988047.jpg
                                      TUBES.skp
                                        Try Profile Builder !
                                        With the free version you can't draw your own profile, but there are always tons inside! ๐Ÿ˜„
                                          banan666
                                          I have tried it before, great tool, but it doesnt work for me with OSCoolean. All the time the same problem, I couldnt make Solid form, its all the time (Group 1 in model) in Entity info and I dont know what happening...
                                          TUBES1.skp
                                          • cottyC Offline
                                            cotty
                                            You just have to close the two ends...
                                            my SketchUp gallery
                                            • 1 / 2
