    Delete hidden components
    7 Posts 6 Posters 5.8k Views 6 Watching
    • BurkhardB
      Burkhard
      I was asked how to delete a bunch of hidden components.
      The workarounds I can imagine are to select the Model and copy it into a new Sketchup instance without the hidden Geometrie or to make a Group of the Object and unhide the rest to select and delete.
      But if the model is around 100MB and I talk about 50000 Components, it took a lot of time.
      Any Idea for a more elegant solution, maybe with a plugin?
      http://www.ia-plus.de
      • focptF
        focpt
        Try the Outliner tool in SU (Window > Outliner). Any group that hidden will be in italics. You can select multiple items and delete from this list.
        • Nathan
          http://www.focalpointstudio.net
        SU8, VRay 1.49
        • TIGT
          If you want to erase ALL hidden component-instances/groups/images used in the model then this one-liner copy/pasted into the Ruby Console + <enter> will do it: it's one step udoable
          m=Sketchup.active_model;m.start_operation('x');m.definitions.each{|d|d.instances.each{|i|i.erase! if i.hidden?}};m.commit_operation
          you can limit it to just component-instances with this version...
          m=Sketchup.active_model;m.start_operation('x');m.definitions.each{|d|next if d.group? || d.image?;d.instances.each{|i|i.erase! if i.hidden?}};m.commit_operation
          If you want to erase other hidden stuff like geometry then it's more complex...
          • thomthomT
            My CleanUp plugin has a Erase Hidden Geometry function. anything that isn't visible when you run it is erased. (It off course ensures not to erase hidden edges that make up a visible face - or acting as the cutout profile for a cutout component.)
            • GaieusG
              This may not be a good method because if there are nested and at the same time hidden groups/components in top level groups/components that you are copying, it will take those to the new model, too.
              • BurkhardB
                Burkhard
                Thanks to all... πŸ‘
                • M
                  monkers
                  Hi Guys, I'm trying to do similar.
                  Is there a way to write a script that could delete all items that get called in outliner per search term. I am trying to clean up a model for rendering provided by a client. The file has every bathroom, sink, door, light, etc for thousands of apartments. Unless I explode everything I have to delete by each level I have managed to separate everything into.
                  Currently I have to go through each definition X each building X each level. Each time I select and delete it takes like 5 minutes. I have already spent a day doing this. It's getting really tedious. 😍
