    [Plugin] Snapshot – (1.0.1) — updated 09.10.2012
    74 Posts 12 Posters 57.4k Views 12 Watching
    • G Offline
      glro
      @aerilius said:
      I first thought it might have to do with upgrading the settings (because the previous version is much different). But I just tested it from 0.1.1 to 0.3.0 and it works for me.
      You mean the settings dialog does not appear when you click the gear icon on the toolbar (there is no ae snapshot menu). Can you open the Ruby Console, click the gear button and give me the error messages if there are any.
      Then copy&paste " AE::Snapshot.options={}" into the console and press the gear button again. Does it then work?
      yes, the setting dialog does not appear;
      the gear icon does'nt appear either...
      just a small reactangle where i cannot click ...
      how do you explain the differences between the setting dialog window i get when i double click directly on the file "settings_dialog.htm" and the one you pasted in you message?
      my guess is that it is linked to the problem
      snapshot icon
      • srxS Offline
        srx
        Very useful! Thank you very much.
        www.saurus.rs
          Aerilius
          @glro: Does " Sketchup.write_default("Plugins_ae", "Snapshot", "{}")" on the Ruby Console and restarting help?
          (There are no relevant differences in the htm file.)
          (By the way, you don't need quote the message, I know it's on the same page one above 😉 )
          • G Offline
            glro
            OK
            yes it helps
            when i close and open sketchup again, the icon and snapshot settings windows appear on the screen
            but i cannot save the parameters (clicking on "OK" doesnt change anything)
            i notice the lines you added to create a file shortcut; since this is the only option i am interested in, i'll try to add them to the previous version, that worked perfectly on my computer
            thank you
              Aerilius
              @glro said:
              yes it helps
              That is good!
              Toolbar changes can only take effect after restarting SketchUp. (Maybe that's not so obviously written.)
              • G Offline
                glro
                when i launch sketchup again, i get "wrong number of arguments (0 for 1)"
                The plugin does take a shot when i click on the button
                but i cannot get the snapshot settings windows on the screen anymore
                it may be because of my computer, if i am the only one to have this problem...
                  Aerilius
                  I am very sure it's not your computer. I couldn't find anything on my own.
                  This error was on the Ruby Console? Can you tell me what was before or after that? There should be a line number and a line number is very much helpful!
                  • G Offline
                    glro
                    no, nothing in the ruby console
                    it is an error message when sketchup loads all the plugins
                    no numbers
                    erreur chargement
                      Aerilius
                      Ok, SketchUp does not tell us much about load errors. In such a case we need to reload the plugin manually in the Ruby Console to see more details. Can you do:
                      load "ae_Snapshot/Snapshot.rb"
                      • G Offline
                        glro
                        Here is what i get when i type 'load "ae_Snapshot/Snapshot.rb" 'in the ruby console
                        Error: #<ArgumentError: C:/Archivos de programa/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:309:in `initialize': wrong number of arguments (0 for 1)>
                          Aerilius
                          Thanks!!!
                          I found and fixed the issues!
                          • G Offline
                            glro
                            sorry to write that i still have an error message
                            string to integer error
                              Aerilius
                              I'm not sure if I found it (line 187?). Can you post the error with line number that the Ruby Console gives?
                              • G Offline
                                glro
                                Here is the error message:
                                "Error: #<TypeError: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319:in []': can't convert String into Integer> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:318:in each'
                                (eval):155:in `load'
                                (eval):155"
                                line 319
                                  Aerilius
                                  (I won't be back until tomorrow.)
                                  I just made a quick change, can you test it?
                                  Put it in .../Plugins/ae_Snapshot/Snapshot.rb
                                  • G Offline
                                    glro
                                    i replaced the previous file in the rbz, by this new one, and yes, now it works perfectly
                                    a nice tool to keep tracks, and retrieve a lost model
                                    thank you
                                      driven
                                      been playing around with style
                                      no need to open, but do the icons download to other computers
                                      don't stay stuck when on the file posting, but I want to test if they download
                                      This is the Standard horrible mac one
                                      it's icon doesn't upload either??
                                      john
                                      • simon le bonS Offline
                                        simon le bon
                                        This last release is impressively highly configurable - And then need to be tamed a bit
                                        The fact is that I'm not easy with the {nr} parameter and the "change digit by" line bellow. 😳
                                        I'm not able to make the incrementation work.
                                        Whatever I test, I obtain something like this: xyz_00**_1-0-0**.png ❓
                                        Need some further explanation 💭 😒
                                        simon
                                          Aerilius
                                          Whatever I test, I obtain something like this: xyz_00_1-0-0.png
                                          That depends on what you want to get (I don't know).
                                          It's the printf format (I didn't need to implement it, otherwise it would be more complicated). You can write any separating characters and %d is replaced by the number.
                                          It should work that for a major version 1, minor version 3, you get
                                          [pre:1z9sy1o8]%d → file_1.skp
                                          %d.%d (or %1d.%1d) → file_1.3.skp (number between %d sets minimum width)
                                          %d.%2d → file_1. 3.skp (minimum width is filled up by spaces)
                                          %d.%02d → file_1.03.skp (with additional 0, it is filled by 0)
                                          %d-%02d → file_1-03.skp
                                          %d_%02d → file_1_03.skp
                                          %02d.%02d → file_01.03.skp
                                          %02d.%03d → file_01.003.skp[/pre:1z9sy1o8]
                                            simon le bon
                                            Ok, thank you! I understand very better now.
                                            But Hum! incrementation still dont work for me. Is it something I'm doing wrong or is it something that don't work with the script ?
                                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Aerilius_Snapshot_005.jpg
                                            By pressing my +1 button set as above
                                            a xyz.skp Snapshot should be saved as
                                            and due to "change the 2 digit by 1", I understand that the following +1 button depressed should increment the files by the second digit:
                                            xyz_01_03.png...
                                            But my file is saved as
                                            xyz_01_00.png and instead of increment it , overwrites on itself.
                                            Still need help I guess 😳
                                            Simon.
                                            • 2 / 4
