    Check the Artisan update
    14 Posts 8 Posters 1.4k Views 8 Watching
    • esteromxE
      esteromx
        Cool indeed 😄
        • pbacotP
          Bumping, this is impressive!
          Now if only an grid like this could be generated from contours. this might be a fantastic way to work site terrain.
          • mitcorbM
            mitcorb
            I could vote for that, if it would not be too difficult.
            Edit. By the way, these updates are excellent.
            • thomthomT
              Isn't there a plugin that generates quad-shapes topology from arbitrary terrain mesh?
              I can't remember the name right now though...
              • pbacotP
                Hmmm, think there is... could work in the right hands.
                • P
                  Panga
                  If you find it, I want it ! There's some plugins to recreate a mesh on a terrain, but the ones I know are not really straightforward and do not work with quads...a real retopology tool with quads in SU would be really awesome !! 😲
                  Edit : And existing plugins are quite slow for processing terrains and create new geometry.
                  • thomthomT
                    New feature for QuadFace Tools maybe? I'll write it down for investigation.
                    • P
                      Panga
                      I'll follow that with hight interest !! Could be definitly a real plus for landscaping, but I think for many other activities !
                      If I can help you in any way in this, I'm here !!
                      • pbacotP
                        I've been trying with QFT, but it eludes me. Sometimes I end up with a mess of overlapping faces...
                        been dreaming along these lines:=http://sketchucation.com/forums/viewtopic.php?f=15&t=44282&p=414933&hilit=+contours#p401481
                        Alsohttp://www.formz.com/products/bonzai3d/bonzai3dFeatures.php?init=27
                        I've tried doing it manually --pull a grid up to the contours with the sculpt tool. Doesn't work too well.
                        • P
                          Panga
                          So do I.... 😄
                          • N
                            nektares
                            Could someone tell me how does dale deform the "quads" without getting visible triangulation? if i subdivide manually with lines it gets triangulated and if i subdivide it with artisan subdivide it gives me triangles too but i see on this video a different behavior, am i missing something? is he using another plugin? i hope someone can help me! cheers!
                            Amazing update btw, i was daydreaming about the jitter function for randomizing the surface and suddenly i got it and i´m extra happy.
                            • massimoM
                              massimo Moderator
                              If you start with a "from scratch" mesh from the sandbox tools then you'll have no visible triangles because the diagonals are hidden. It's the same principle that Thom used here I believe.
                              • N
                                nektares
                                i see, thanks massimo (y)
