    Match photo axes?
    17 Posts 4 Posters 1.0k Views 4 Watching
    • P Offline
      puppychew
      Hi - I am in the process of learning SU.
      I have a photo of the front of a house. There is no side view to adjust for perspective. Is is still possible to use the match photo function and line it up?
      I need to add a porch to the house in SU and will need to rotate it to do the porch.
      Thanks,ken
        It does really need a 'corner view' to let you set the three axes with any degree of accuracy.
        However unless you picture is completely square-on there might well be some bits 'in perspective' that would allow you to get the axes front-to-back - the left-right up-down axes being easily got.
        Are there no projecting sills, roofs, bay-windows, short-return-walls, orthogonally arranged steps or paving-slabs etc that give this clue ?
        Can you attach the picture to your next post ??
        • P Offline
          puppychew
          Here is the house pic. Do you think I can use one of the floor board on the porch?
            Not really anything to use to set up the Axes for Photo Match. I'd be inclined to import the photo as an image instead of Match Photo. You can scale the image pretty closely and the basically trace it.
            This covers doing something similar to what I would do with your photo.
              I recommend the 'Image' method that Dave suggests...
              Here's the PhotoMatch version - it doesn't quite have enough 'perspective'...house.skp
              • P Offline
                puppychew
                So if I bring it in as an image, I can trace the outline of the front. I guess then I would use the push-pull to make it more of a box so I can rotate it and then copy the image on the front of the box (house). I can then construct a railing and balusters on the porch. Does this sound right?
                  Well, yes, you would trace over it and use Push/Pull to turn it into a box. You could actually the explode the image and it would be applied to the front of the house. You can then add whatever other details you need. If you wanted you could give the door and window some depth and add the roof overhang and so on.
                  • P Offline
                    puppychew
                    Not sure I understand what you mean about exploding the image to apply it to the box.
                      If you import the image as an image and not as a texture, it will be an entity of its own. You can stand it up, size it as needed (as I showed in the link I gave you) and trace over it without changing it. If, after tracing over it and creating faces for the house model, you context click on the image, you'll have an option to Explode. Then the image becomes a texture applied to a face. You can then apply that texture to your house model.
                      Here's a quick example.
                      Image imported as an image into SketchUp. Outline traced onto image but it isn't part of the image.
                      Image exploded and the unneeded bits deleted. The image is now a material applied to the house. You could make a 3D model of the house and apply the material to it. I just didn't take it that far. If this is your only image of the house, you're kind of on your own for the other sides.
                      • P Offline
                        puppychew
                        WOW I actually did it! This is a big deal for me since i am still learning. Thanks so much for your help!
                          Roger
                          What inhibits you from getting a 3/4 view photo? Just curious.
                          http://www.azcreative.com
                          • P Offline
                            puppychew
                            I am working on a job for someone out of state. Normally I do architectural design in photoshop and autocad but SU can really help. If I ask the client for an angled photo then the other work I did would be out of wack.
                              Roger
                              Ken, I don't follow the "out of wack" part. You can model the other wall from a 3/4 view or an elevation view it does not really matter. You can even build that other wall as a separate file and then import it into your current file (rotated to fit your depth axis). If the dimensions are alittle off, you can stretch or compress the new wall to fit. Uou do know that you can change your scale or units of measure at any time in the design process? If the texturing of the new wall does not match that can be fixed too, I am just assuming that wall we cant see is made of the same clap boards and not Carrera marble. So you take you original front photos and select the biggest uninterrupted clapboard span you can find. You import that into photoshop, correct the parallel lines and tonal evenness and make it into a new material. Then after poking out windows etc. you click load the paint bucket with your new texture and with one click paint the whole side of the building to match the front. By using tricks of the trade there should be no "out of wackness" once you master the power of the program. Extra source material should only help and not hider your ability to deliver a good product. You will stub your toe learning new tricks, but in the longer run things will get simpler. Try new stuff and ask very specific questions on this forum an you will get a lot of help.
                              • P Offline
                                puppychew
                                You're right - Thanks Roger
                                • P Offline
                                  puppychew
                                  one more problem. I have new lattice for under the porch. I did the same with that image - exploded and deleted all but the lattice. I then imported it into the main file with the house. I am not able to take that section and place it on top of the image - it only goes behind it.
                                    Roger
                                    Post the file and I will show you how to place the lattice.
                                      Make the lattice into a component or group and place it where you need it in the model. Remember you're working in 3D space so you can place one thing in from of another.
