    Little headache [resolved] +...
    25 Posts 6 Posters 1.1k Views 6 Watching
      After a Sandbox from contour
      How to kill all faces inside the internal circle ? (or the inverse how to select faces from the inverse of the internal circle? )
      (except kill one by one)
      red faces are the "blue inverse":)
      Here the internal, external circle can always be selected
      • pbacotP Offline
        left right select center part (it is possible--no radiating edges or far outside edges). Group. Delete.
          Circular Selection tool in Vertex Tools
          Top View > Paralell
          Select
          Kill
            @ Rich : not fair it's $ plugin πŸ˜‰
            @ pbacot : sorry I don't understand 😳
            Ah yes a box selection ? β˜€
              To kill you must pay.
              Or Artisan Brush select. Set radius to inner ring. Click and kill.
              Only the great plugins are $
                Roger
                Or swipe the erase tool through that mess a couple times while holding down the "ALT" key.
                http://www.azcreative.com
                  In fact I just find! 😍
                  A simple box selection from left to right with a good first point clicked! (up left on the disc) 😳 πŸ’­
                  It's the Pbacot answer that I don't understand who gives me the key πŸ˜„
                  Many Thx to him πŸ‘
                  I had tested numerous solutions except this simple one! πŸ˜’ πŸ’š
                  • pbacotP Offline
                    Top View > Paralell
                    Select
                    Kill
                    I don't see how this works. All you can select is vertices and you loose the outer ring.
                    Make it harder.
                    another headache.skp
                    • pbacotP Offline
                      I'm trying to learn video recording but by the time I manage one, you'll have figured it out.
                        @pbacot said:
                        I don't see how this works. All you can select is vertices and you loose the outer ring. Make it harder.
                        302 Found
                        (www.screenr.com)
                        Works for me. But I did leave out some info
                        If you wanna do a quick screen capture with audio or without try screenr.com
                          @ Roger: Valuable on a little surface and with many zoom! πŸ˜„
                          • pbacotP Offline
                            Turn off hidden geometry. By double clicking face to select face and outer edges, then shift-click (deselect) face, you choose only outer edges. Offset tool. Offset outer edges to inner ring (SU snaps to hidden edge). May have to do this twice to get a hard inner ring edge. Select all. Shift and double click outer face to deselect. Erase. Native tools.
                            You don't have to buy tool (but it's REALLY worth it).
                            OK Rich I see, exit the tool. Thanks, Peter
                              16 seconds : that's a task πŸ˜‰ πŸ‘
                                Your last solution gives me another one πŸ˜‰
                                because your Offset tool seems don't snap on Outer "Vertext" or middle of segment circle! 😲 bug ?
                                just snap on the inner circle at the end 😲
                                So difficult to fit the 2 circles πŸ˜‰
                                So Top View
                                Turn off Hidden geometry
                                draw a circle from the Center to the inner cirle (you must know the number of sides circle of course πŸ˜‰
                                Double click on the disk between inner and outer circle
                                Invert selection (By TIG)
                                Erase πŸ˜„
                                • pbacotP Offline
                                  So Top View
                                  Erase πŸ˜„
                                  Works OK for me to use the offset tool--but this is if the original ring is an exact offset. I don't try to snap anything. Just move in and it finds the snap. For some reason I had to do it twice sometimes.
                                  Rich, Maybe I'll try Screenr-- it starts out by requiring me to update system software because it doesn't recognize my java. So it'll be hours.
                                  OK I figured the screencast out. Not that great because I should have given audio. But my first screencast! Thanks Rich!
                                  http://www.screenr.com/Hh38
                                    I went slow to see the action 😎
                                      driven
                                      I always use 'cut' >> 'paste in place' for this type of selection.
                                      Select 'contours' >> 'Sanbox' from contours >> Select 'contours' [not new group] >> 'Cut' >> 'Edit' group >> 'Paste in Place' >> Select 'surface' between contours >> 'Cut' >> 'Select All' >> 'Delete' >> 'Paste in Place'.... Done
                                      john
                                        A little tricky but works like a charm! πŸ‘
                                        • P Offline
                                          Panga
                                          Something a bit like what driven said..
                                          Select contours...Copy it...use sand box tool...edit created terrain...paste in place contours and then delete unwanted faces is really easy as all edges are soften except the contours you pasted in place...(make sure hidden geometry not visible of course !).
                                          Cheers.
                                            Seems with this last solution the erase don't works in one click! 😲
                                            Some little faces stay so you must make some clicks more πŸ˜„
                                            • 1 / 2
