    Little headache [resolved] +...
    25 Posts 6 Posters 1.1k Views 6 Watching
      I'm trying to learn video recording but by the time I manage one, you'll have figured it out.
        @pbacot said:
        I don't see how this works. All you can select is vertices and you loose the outer ring. Make it harder.
        302 Found
        (www.screenr.com)
        Works for me. But I did leave out some info
        If you wanna do a quick screen capture with audio or without try screenr.com
          @ Roger: Valuable on a little surface and with many zoom! πŸ˜„
            Turn off hidden geometry. By double clicking face to select face and outer edges, then shift-click (deselect) face, you choose only outer edges. Offset tool. Offset outer edges to inner ring (SU snaps to hidden edge). May have to do this twice to get a hard inner ring edge. Select all. Shift and double click outer face to deselect. Erase. Native tools.
            You don't have to buy tool (but it's REALLY worth it).
            OK Rich I see, exit the tool. Thanks, Peter
              16 seconds : that's a task πŸ˜‰ πŸ‘
                Your last solution gives me another one πŸ˜‰
                because your Offset tool seems don't snap on Outer "Vertext" or middle of segment circle! 😲 bug ?
                just snap on the inner circle at the end 😲
                So difficult to fit the 2 circles πŸ˜‰
                So Top View
                Turn off Hidden geometry
                draw a circle from the Center to the inner cirle (you must know the number of sides circle of course πŸ˜‰
                Double click on the disk between inner and outer circle
                Invert selection (By TIG)
                Erase πŸ˜„
                  So Top View
                  Erase πŸ˜„
                  Works OK for me to use the offset tool--but this is if the original ring is an exact offset. I don't try to snap anything. Just move in and it finds the snap. For some reason I had to do it twice sometimes.
                  Rich, Maybe I'll try Screenr-- it starts out by requiring me to update system software because it doesn't recognize my java. So it'll be hours.
                  OK I figured the screencast out. Not that great because I should have given audio. But my first screencast! Thanks Rich!
                  http://www.screenr.com/Hh38
                    I went slow to see the action 😎
                      driven
                      I always use 'cut' >> 'paste in place' for this type of selection.
                      Select 'contours' >> 'Sanbox' from contours >> Select 'contours' [not new group] >> 'Cut' >> 'Edit' group >> 'Paste in Place' >> Select 'surface' between contours >> 'Cut' >> 'Select All' >> 'Delete' >> 'Paste in Place'.... Done
                        A little tricky but works like a charm! πŸ‘
                          Panga
                          Something a bit like what driven said..
                          Select contours...Copy it...use sand box tool...edit created terrain...paste in place contours and then delete unwanted faces is really easy as all edges are soften except the contours you pasted in place...(make sure hidden geometry not visible of course !).
                          Cheers.
                            Seems with this last solution the erase don't works in one click! 😲
                            Some little faces stay so you must make some clicks more πŸ˜„
                              driven
                              Variation.....
                              Select 'contours' >> 'COPY' >> 'Sanbox' from contours >> 'Edit' group >> 'Paste in Place' >> Select 'surface' between contours >> 'Cut' >> 'Undo' >> 'Undo' >> 'Undo' >> 'Paste in Place'.... Done
                              use Undo to remove unwanted.
                                Panga
                                @driven said:
                                Variation.....
                                +1 Using undo and paste in place is often the better solution !
                                  This was first made by Sandbox from Contours. If you just save the circle contours in the first place and paste into the skinned group, you have a defined outer ring face to select separately. So don't throw away the contours in the first place.
                                  Another way to work with the problem is to select the outer edges by drawing a rectangle around the whole thing so you can double click the outer face of that. Once you have the outer ring alone selected you can lift it up so that the center section can be isolated-- right/left click and delete.
                                    @panga said:
                                    @driven said:
                                    Variation.....
                                    Why not just select the surface between contours, copy, close group and erase, paste in place? why the undo's? Just take what you wanted and throw the rest away.
                                      Panga
                                      @pbacot said:
                                      @panga said:
                                      @driven said:
                                      Variation.....
                                      I like the undo 'cause this way I'm sure there's not unused components in the file...It's not a problem here as the created terrain is a group, but It's an habit I have.
