    Colourizing a material
    14 Posts 7 Posters 853 Views 7 Watching
    • R
      ryangarnett
      Hi All,
      This may be a dumb question, but is there a way to place a material (ie: metal or brick) and them paste a colour over it, to have the texture roughness of the material, but have a range of different colours?
      Thanks....
      • TIGT
        This is three different materials using the same image two are 'colorized' - see the edit settings...
          You can do as TIG shows or, if you need more control over editing the appearance of the material, right click on its thumbnail image in the In Model material library and choose Edit Material... then do what you need to do in your favorite editor and save it. You'll need to tell SketchUp what editor you're using under Preferences>Applications.
          • R
            ryangarnett
            Thanks Guys. I knew about the external editor. Within other 3D packages you can do a layering effect, similar to the old encyclopaedias that had the human body as a see-through layer. So you would have a material (brick), then you could add a new layer as a colour (purple) and set the transparency. This would allow you to use one material texture, but have an endless colour variation.
            Thanks for the help...
              I do that with wood grain material images to create an appearance of the wood being stained. Generally for those I convert the original material image to gray scale. Then I use a transparent color applied to another layer to adjust the color.
              This hickory material was given a brown stain that way.
              @N08/5657550273/" target="_blank" rel="noopener noreferrer nofollow ugc">
              http://farm6.staticflickr.com/5023/5657550273_9ccf4a789d.jpg
              • GaieusG
                Note however that TIG's method does not actually colourize the image itself so when you export your model to a 3rd party application, you will get the base material.
                • pbacotP
                  Gai,
                  When does that apply? I ran a test in Maxwell fire, and as I thought, if I color a texture via the materials menu SU it shows colored in Maxwell. Perhaps I am not thinking "3rd Party" correctly?
                  Peter
                  • GaieusG
                    Hm. Does that run under SU?
                    Try to colourize a material then right click > texture > edit texture image. It should get the original image only.
                    (It was in a topic lately where someone was suffering with this and I also tested and could not get the coloured material to render).
                    • pbacotP
                      That's right. If I send to GIMP, it is only the original uncolored image. I thought you meant for rendering, which does seem to get the coloring fine....
                      • GaieusG
                        Well, the same happens when exporting (say) to collada (I think) so probably some external renderers would still not see the colouring.
                        • pbacotP
                          Maybe has to do with a dedicated exporter. Kerky and Maxwell pick it up.
                          • GaieusG
                            Well, I don1t know Maxwell but I know that Tomasz puts a lot of care and love into his exporters. πŸ‘
                            • panixiaP
                              panixia
                              vray doesn't recognize sketchup-colorized textures. it just renders the base image.
                              • V
                                Vicspa
                                What about the import to Photoshop link, providing one has Photoshop.
