    Creating a 3D Wall Panel
    Scheduled Pinned Locked Moved Organic Modelling
    23 Posts 12 Posters 14.1k Views 12 Watching
    • neetsN Offline
      neets
      Hey everyone,
      I'm hoping for a little bit of direction on how to create organic forms. I have attached a photo of a wall panel that I'd like to create in Sketchup but haven't a notion how to create it. You'll see that it is like a 'dune' shape, which obviously makes it 100 times more difficult because of the sweeping angles/geometry. Any ideas??
      Anita
      Interested to know more about me and my 3D Visualisation work? Then you want to click right here: http://anitabrowndesignstudio.com/
        Try CurviLoft.
        • DareDevilD Offline
          DareDevil
          It's stretched fabric, so use Ferrari Sketch or Soap Skin Bubble
          Ferrari Sketch
          Soap Skin Bubble
          and you can do something like that :
          • neetsN Offline
            neets
            Thanks for your replies πŸ˜‰ Daredevil....wow, you've hit the nail on the head!! Well done!! Now all I have to do is a little bit of experimentation - see you in about 3 months!! lol
            Neets
            • neetsN Offline
              neets
              Daredevil, I'm getting nowhere fast - can you take me through how you created that wall panel??
              Neets
                mac1
                A simple approach;
                1. Create a small say 24"x24" basic tile;
                2. On that face draw the desired profiles. You can use an ARC, Bezier etc
                3. Create the face on the surface using the suggestions above, TIGS extrude,ARC tools.
                4. Make tha tile a component;
                5. Using that component replicate it in a x y grid, circular array etc. or manually. SU has an native array( linear or circular) function you may find useful'
                  The attached skp was made with the SU ARC tool and the Soap Skin AND Bubble plugin to create the 1/4 face
                  Do not try and use the follow me tool if the profile needs to be adapative to follow the edge.
                  Good Luck
                3d wall panel.skp
                  That's a nice result DD πŸ‘
                  Had a go using just native tools.
                  http://www.screenr.com/ZCu8
                  • boofredlayB Offline
                    boofredlay
                    Anita, welcome to SketchUcation.
                    All of the methods mentioned are great. One thing I would make sure to do is reduce the polygon count however. If you are going to use this across an entire wall the poly count can grow very fast and slow your model down significantly. Unless you are doing a close up product shot a low poly model should suffice.
                    Attached is a tut on how I would accomplish this shape. All simple basic SU tools.
                    Cheers.
                    Wall Tile.skp
                      πŸ‘
                      Legend
                      • neetsN Offline
                        neets
                        Mac1, Rich and Boofredlay
                        This is exactly the kind of assistance I need - thankyou, thankyou, thankyou!! πŸ˜„ I will have a go at this myself later (have to do grocery shopping now...ugh) and let you know how I get on.
                        Boofredlay, as you say I might only use this effect on a small portion of the wall - I was initially going to use it on the entire wall but I felt it might have been too much for SU to handle.
                        Thanks again guys πŸ˜‰
                        Neets
                        • neetsN Offline
                          neets
                          Rich - your tutorial was spot on. Thanks for taking the time to do that, it's now in my Favourites - much appreciated πŸ˜„
                          Boofredlay - I followed your steps and was able to create the same shape. Gold star for you πŸ˜„
                          You people are legends!!! My only issue is that you don't live next door...is that a sigh of relief I hear??!!
                          Anita
                          #sketchucationrocks
                            boofredlay
                            Glad to help.
                            • Bryan KB Offline
                              I did much the same thing except after forming the square and the arches, I then used From Contours.
                                Any chance to see it in v6 ? πŸ˜‰
                                  boofredlay
                                  Wall Tile v6.skp
                                    Thx for the V6 😎
                                    Tricky indeed! β˜€
                                      boofredlay
                                      That just gave me migraine.
                                      • GarethG Offline
                                        Gareth
                                        Pilou,
                                        Have you been eating those strange mushrooms again..??!!
                                        • gillesG Offline
                                          gilles
                                          A very simple way to do it:
                                          Autofold_V6.skp
                                          Minitel version
                                          • K Offline
                                            keyston
                                            Also can use fredo's curviloft skinning following 2 paths. fairly low poly result. πŸ‘
                                            Actually, the result is exactly the same as in gilles method.
                                            • 1 / 2
