    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 324.2k Views 57 Watching
      Research of the perfect voluptuous inaccessible curves! β˜€
      • pbacotP Offline
        Thank you Fredo! This looks fantastic. Thanks for everything...looking of Donate button.
        • cottyC Offline
          cotty
          Thank you not only for the impressive plugin, but also especially for the excellent and detailed documentation (PDF)!
          my SketchUp gallery
          • fredo6F Offline
            fredo6
            @guanjin said:
            Thanks for update again, but the language translation problems still exist, thank you!
            [attachment=0:2dklo00h]<!-- ia0 -->ζœͺ命名.jpg<!-- ia0 -->[/attachment:2dklo00h]
            Thanks for signaling the bug. I fixed it and will republish.
            But before I do, do you have the Curvizard_ZH.lang file so that I integrate it in the release.
            Fredo
            • guanjinG Offline
              guanjin
              [attachment=0:22t88ozw]<!-- ia0 -->ζœͺ命名.jpg<!-- ia0 -->[/attachment:22t88ozw]
              Fredo
              Dear Fredo6: Chinese language file has been sent to your mailbox, please find Thank you!
              I come from China, is to learn
              • OxerO Offline
                Oxer
                Thanks Fredo for the update it's very useful !! πŸ‘
                The problem with the translation continues and missing some translations. I have done the Spanish translation (Spain) but how i say you there are missing translations.
                Thanks again Fredo.
                Spanish Language (Spain)
                [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
                • fredo6F Offline
                  fredo6
                  Oxer,
                  Thanks very much for the update.
                  Note that part of the transaltion is in LibFredo
                  The issue with the translation effective in the Luancher and tooltips of the main icons will be fixed in release 1.1b.
                  Fredo
                  • OxerO Offline
                    Oxer
                    Thanks Fredo!!
                    • fredo6F Offline
                      fredo6
                      NEW RELEASE: Curvizard v1.1c - 29 Nov 12
                      Minor release over 1.1a:
                      • fix a problem in Cleanup Contour which cannot be launched
                      • fix to a problem for translation for the Quick Launcher
                      • Integration of Chinese translation (guanjin)
                      • Update to the Spanish (Spain) translation (Oxer)
                      See main post of this thread for Download.
                      Fredo
                      • ArcA Offline
                        Arc
                        Translation into Chinese...
                        Chinese language
                          smicha
                          Fredo, You are genius!!! Thank you so much for fantastic update.
                          • V Offline
                            victor hugo
                            Pretty useful plugin!!!
                            I've downloaded the update 1.1c and installed per instructions and when I go to "Fredo tools" to "Check the Plugin Update"; Curvizard still shows in pink/red. I re-downloaded the file and it keeps saying I need to do update!!!??
                            Thanks.
                            • cottyC Offline
                              cotty
                              1.1c or 1.1d?
                              my SketchUp gallery
                              • V Offline
                                victor hugo
                                I had 1.1c and just did 1.1d and the attched is what is showing
                                Thanks.
                                • cottyC Offline
                                  cotty
                                  You are right, it seems that in the 1.1d file "Curvizard.plugin" the version is still 1.1c ...
                                  my SketchUp gallery
                                  • guanjinG Offline
                                    guanjin
                                    I am also, but does not affect use.
                                      small08
                                      Amazing work Fredo, Thank-you!
                                        matt.gordon320
                                        Hi Fredo,
                                        I was wondering if you might be able to take a look at my office's model to see what might be causing the error(s) I'm getting? I've attached both the model and the error report.
                                        Thanks!
                                        Matt
                                        Master Topo Clean ERROR.skp
                                        Ruby Error - Curvizard#simplify_curve - 10-Dec-12 13_43_35.txt
                                          Matt
                                          What are you trying to do when you get the error message ?
                                          Your post is too scant. πŸ˜•
                                            matt.gordon320
                                            My apologies, my message is absolutely lacking in any detail 😳
                                            I've brought in a dwg containing topographic information from a civil consultants's office, and I'm trying to use Curvizard to simplify the contours. When I do, the interface of SketchUp pauses for a second, then comes up with an error message window containing the information in the attached text report. I can't quite figure out what the error is, or whether it's something that I introduced through cleaning up the DWG, or whether it's something that is just lost in translation from AutoCAD => SketchUp.
                                            Hope that's better πŸ˜„
                                            Thanks!
                                            Matt
                                            • 9
                                            • 10
                                            • 3 / 10
