    I have a problem with su
    7 Posts 5 Posters 369 Views 5 Watching
      joy6996
      Hi,everyone.now I have a problem with su modeling .here is a building i want to modleing ,but i don't know how ,I have no method to do it,can someone help me ,thanks .
      • jeff hammondJ Offline
        jeff hammond
        make a blob and slice it up.. that's what they did.
        (hard to tell anything more precise without knowing your experience level.. show a jpg of your attempts so far)
        dotdotdot
        • cottyC Offline
          cotty
          Here is an excellent slice tool from TIG...
          http://forums.sketchucation.com/viewtopic.php?t=42267#p374969
          my SketchUp gallery
            joy6996
            I try to do it ,and I only could doing like this .
              You have the form made.
              Make a group of it.
              Use my Slicer tool on that - with appropriate slices' axis, thickness and gap etc...
              • brookefoxB Offline
                brookefox
                TIGs tool no doubt would be the easiest (I have not used It) but you could easily slice it manually with the native tools: draw some vertically oriented faces through the shape and intersect them with it. You are almost there.
                ~ Brooke
                  joy6996
                  Thanks everyone ,i solve the problem ,i use Bezier Spline plug and curviloft plug to build the shape ,then use the slicer plug ,so the result likes this
