    [Plugin] WireTool (Catenary) (1.4.1) – updated 06.03.2013
    54 Posts 26 Posters 62.5k Views 26 Watching
      Aerilius
      This Plugin allows to draw physically accurate wires and ropes (catenary curves) between two points with only two clicks.
      [floatr:t2flpn38]preview.png[/floatr:t2flpn38]
      Installation: Open Window → Preferences → Extensions → Install Extension and select this file; alternatively use an unzip program to extract the contents into the SketchUp/Plugins folder. [previous downloads: 778]
      Version: 1.4.1
      Date: 06.03.2013
      Usage:
      (Menu) Plugins → Draw Wires
      • Type a number + %(#000000)[s] to change the number of curve segments:
        %(#000000)[24s]
      • Type a number + %(#000000)[%] to set an arc length (relative to the distance between source and target point):
        %(#000000)[120%]
      • Type a length to set a fixed arc length:
        %(#000000)[72.5m]
        %(#000000)[30.66"]
      History:
      version 1.4.1: 06.03.2013
      • added Spanish translation
      • fixed non-convergent numerical approximation for curve lengths near 100% of distance
        version 1.4.0: 01.03.2013
      • converted into a SketchUp Extension
      • image and cursor added
        version 1.3: 03.06.2012
      • fixed wrong segment length (only noticeable with big sag like 200%)
      • changed segments to have equal angles (visually best result, but not all segments have the same length)
      • added optional parameter @@segment_distribution_mode in the script to toggle back to equal length segments (edit the ruby file)
        version 1.2: 30.05.2012
      • now all segments have equal arc length (no more equal x length)
      • error with translation in activate didn't properly activate the tool
      • @state=0 fixed
        version 1.1: 27.05.2012
      • translations
      • better precision (changed threshold for numerical calculations)
        version 1.0: 27.05.2012
      • KrisidiousK Offline
        Krisidious
        sweet thanks.
        By: Kristoff Rand
        • Bob JamesB Offline
          Bob James
          I can really use this! Thank you. 👍
            !!! I tried on this a couple of years ago! Never worked out how to do a fixed length curve. I need to snoop around in your code. I wanted to make a tool that would anchor the end point to other geometry so when you moved of the the object it was attached it the curve would update.
            • iichiversiiI Offline
              iichiversii
              Now this is a great plugin, thanks 👍
              Bring on the Rain...
              • gullfoG Offline
                gullfo
                very cool! this is one of the more useful shapes in acoustics!
                Glenn
                http://www.runnel.com
                  That I wasn't aware of. Guess I need to read up on it again.
                  • mitcorbM Offline
                    mitcorb
                    Another good tool concept. By the way, Remus Knowles has another version in the Plugins Index.
                      iichiversii
                      Any idea what his version is called?
                        Aerilius
                        Remus' plugin is the Simple Catenary Curve. It "just" calculates the curve for a given set of 17 points but it put me on the right path to look on Wikipedia after I had a paper full of integrals that didn't want get further simplified.
                        • urgenU Offline
                          urgen
                          HA!...cool idea.thanks Aerilius 👍
                          --pupil forever...------
                          • N Offline
                            nektares
                            I always did this with splines, this is a much better and precise way to do it, Thank you!
                            • sdmitchS Offline
                              sdmitch
                              When I tried the plugin, I kept getting a canatnary drawn from the origin to my first pick point. Adding a @state = 0 to the def initialize method fixed this problem.
                              http://sdmitch.blogspot.com/
                                Aerilius
                                Hi Sam,
                                thanks for the tip. I wonder why this happens, although the initialize method does not have @state=0, this should be set when the activate method calls reset.
                                Is someone else having this problem?
                                • massimoM Offline
                                  massimo Moderator
                                  Yes the same here. Thanks for the plugin btw. 👍
                                    create_geometry and draw_geometry can be refactored into one method that returns an array of point3d objects - the only difference between these methods are the final statement. DRY
                                      I didn't experience the same thing that Sam reported.
                                      • gullfoG Offline
                                        gullfo
                                        i added the @state=0 and it made a difference in terms of being able to select the first point. very nice tool!
                                        Glenn
                                          So why don't I have this same problem? I didn't modify the script and it works fine for me.
                                          • wind-borneW Offline
                                            wind-borne
                                            Which version are you using?
                                            initial version works fine for me, updated version moves to origin.
                                            "To read between the lines was easier than to follow the text."OSX 10.11.6
                                            %(#BF80BF)[SU 8 pro
                                            • 1 / 3
