    Simple DEselect action or tool/ button?
    11 Posts 5 Posters 5.7k Views 5 Watching
    • O
      osage
      Hi guys. Does anyone know if there is an existing method within Sketchup for DEselecting an entity. Here is my problem. If I am zoomed in on a model, where it completely fills the screen, and I select an incorrect entity, the only way(that I've found) I can "deselect" it, is to zoom out until there is empty space(what do you call that?) that I can left click in, which then "deselects" the entity. I don't need a fancy plugin, as this simple action is all I need. Like some kind of Cont/Alt action? I did a search on deselect, and found there are many plugins, most of which go in the Ruby console..which I don't know a thing about. I get kind of hesitant about loading new plugins too. A few that I've loaded ended up with a Sketchup boot screen saying something like.."Unable to load X...." or something to that effect. I still have one popping up, and I asked to no avil here a while back. I even made sure the plugin was in the right folder but it still pops up. Anyway, any help with a simple entity deselect tool or button or action would be appreciated.
      • GaieusG
        Use the modifier keys.
        Shift will toggle selection (select / deselect)
        Ctrl will always add to the selection
        Shift+Ctrl will always detract from the selection.
        This works both when just clicking on entities and also when using either kind of selection boxes (LTR or RTL)
        • D
          dsarchs
          I'd add that deselect-all can be very useful, as well as a hotkey to back out of a group that you are editing (for when you're really zoomed in, so you don't have to zoom out and click outside of the current group).
          Knowledge is a polite word for dead but not buried imagination.
          -e.e.cummings
          • massimoM
            massimo Moderator
            Ctrl+T isn't good enough?
            • GaieusG
              That works. What shortcut is that by the way?
              (asking preparing for a duh moment) πŸ˜’
              • massimoM
                massimo Moderator
                http://support.google.com/sketchup/bin/answer.py?hl=en&answer=116388&topic=2457922&ctx=topic πŸ˜‰
                • GaieusG
                  Doh...
                  http://users.atw.hu/swb/smile/gulu.gif
                  • O
                    osage
                    πŸ‘
                    If I had known that...I wouldn't be asking now would I?
                    At least you didn't call me a dolt. πŸ˜†
                    Thanks guys.
                    • jeff hammondJ
                      jeff hammond
                      [fwiw.. in case any mac users come across this thread.. that's shift-cmmd-A on mac… (cmmd-A = select all… add shift key for deselect all)]
                      dotdotdot
                      • massimoM
                        massimo Moderator
                        Sorry, didn't mean to be rude. That was mainly addressed to Gai. Since he didn't reply promptly, I was not sure I understood your question properly.
                        In the link I posted there is also a Mac version of the shortcut. πŸ˜‰
                        • jeff hammondJ
                          jeff hammond
                          ha.. i didn't make it that far in the thread before replying 😳
                          dotdotdot
