    Simple DEselect action or tool/ button?
    11 Posts 5 Posters 5.7k Views 5 Watching
    • O
      osage
      Hi guys. Does anyone know if there is an existing method within Sketchup for DEselecting an entity. Here is my problem. If I am zoomed in on a model, where it completely fills the screen, and I select an incorrect entity, the only way(that I've found) I can "deselect" it, is to zoom out until there is empty space(what do you call that?) that I can left click in, which then "deselects" the entity. I don't need a fancy plugin, as this simple action is all I need. Like some kind of Cont/Alt action? I did a search on deselect, and found there are many plugins, most of which go in the Ruby console..which I don't know a thing about. I get kind of hesitant about loading new plugins too. A few that I've loaded ended up with a Sketchup boot screen saying something like.."Unable to load X...." or something to that effect. I still have one popping up, and I asked to no avil here a while back. I even made sure the plugin was in the right folder but it still pops up. Anyway, any help with a simple entity deselect tool or button or action would be appreciated.
      • GaieusG
        Use the modifier keys.
        Shift will toggle selection (select / deselect)
        Ctrl will always add to the selection
        Shift+Ctrl will always detract from the selection.
        This works both when just clicking on entities and also when using either kind of selection boxes (LTR or RTL)
          dsarchs
          I'd add that deselect-all can be very useful, as well as a hotkey to back out of a group that you are editing (for when you're really zoomed in, so you don't have to zoom out and click outside of the current group).
          Knowledge is a polite word for dead but not buried imagination.
          -e.e.cummings
          • massimoM
            massimo Moderator
            Ctrl+T isn't good enough?
            • GaieusG
              That works. What shortcut is that by the way?
              (asking preparing for a duh moment) 😒
              • massimoM
                massimo Moderator
                http://support.google.com/sketchup/bin/answer.py?hl=en&answer=116388&topic=2457922&ctx=topic 😉
                • GaieusG
                  Doh...
                  http://users.atw.hu/swb/smile/gulu.gif
                  • O
                    osage
                    If I had known that...I wouldn't be asking now would I?
                    At least you didn't call me a dolt. 😆
                    Thanks guys.
                    • jeff hammondJ
                      [fwiw.. in case any mac users come across this thread.. that's shift-cmmd-A on mac… (cmmd-A = select all… add shift key for deselect all)]
                      • massimoM
                        massimo Moderator
                        Sorry, didn't mean to be rude. That was mainly addressed to Gai. Since he didn't reply promptly, I was not sure I understood your question properly.
                        In the link I posted there is also a Mac version of the shortcut. 😉
                        • jeff hammondJ
                          ha.. i didn't make it that far in the thread before replying 😳
