    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Mini-challenge
    328 Posts 26 Posters 34.2k Views 26 Watching
      ha.. i always figured you ruby gurus were math wizards.. πŸ˜„
      You really don't need to muddle around with math too much when making plugins for SketchUp. Their API is doing lots of the heavy work. I don't even fully understand the transformation matrix - though reading up on that now.
      nice to know you're sitting around looking things up on a per case basis like the rest of us πŸ˜‰
      I do that for everything I do - always. Simply because I like to know I'm doing stuff correct and efficient.
      • jason_marantoJ Offline
        jason_maranto
        This method still works as expected no matter the distance -- the problem is just that the rotate tool is not precise enough to put the guidepoint exactly where it should be.
        @Jeff -- yeah, sorry my habit is to bring them into a model via the component browser, so it was my fault.
        Best,
        Jason.
        • gillesG Offline
          gilles
          I 've found a tricky way.
          Mini-challenge.skp
          • jeff hammondJ Offline
            jeff hammond
            @dave r said:
            That stuck with me, too. I can't remember who I took to prom, though.
            πŸ˜†
            (I don't think I even went to prom.. maybe)
            dotdotdot
              jeff hammond
              really? sweet!
              I'm on a phone now so I can't see it but the suspense is killing me πŸ˜„
              can anyone verify?
              dotdotdot
                jason_maranto
                Wow, that is tricky... I never would have approached it that way.
                What gave you the answer?
                Best,
                Jason.
                • andybotA Offline
                  andybot
                  Nice one! works for me!
                  • gillesG Offline
                    gilles
                    I dont even know, just an intuition.
                    So do I won something? πŸ’š
                      Yes - the honor of authoring the next challenge! πŸ˜„
                        Unfortunately - the lines are not parallel:
                          jeff hammond
                          [attachment=0:1xhfujx7]<!-- ia0 -->Accuracy.png<!-- ia0 -->[/attachment:1xhfujx7]
                          bah!
                          I was hoping gilles nailed it
                          dotdotdot
                          • andybotA Offline
                            andybot
                            What's missing? I redid it from scratch. I would suggest drawing a guide-line inferenced perpendicular to the new diagonal lines. (I group the newly drawn diagonals so I can rotate exactly to the perpendicular.)
                            diagonal1.skp
                            • TIGT Online
                              My solution - many posts back - using my True-Tangents script's 'True Intersections' - finds the correct point to be used...
                              It also uses "trigonometry" to calculate the values for the point - like the DC...
                              It's as accurate as you can get.
                              My subsequent "plugin-free" approach does it by say three rotate/scale combos until the accuracy is so tiny it could be ignored...
                                jason_maranto
                                I'm also still adamant that the previous approach I showed will work fine -- the only sticky thing about this approach is you may have to manually enter the rotation as the rotate tool will not allow for fine enough control of placing the construction point. The width of the beam stays absolutely perfect -- and the only precision issue is the height of the beam before rotation (as set by the construction point).
                                Bonus here -- no maths 😍
                                Best,
                                Jason.
                                • andybotA Offline
                                  andybot
                                  Nice, yes, that method gets the intersection point correctly as not relying on the segmented SU cricle for the intersection. Thanks for pointing out your tangents tool. I still will use ACAD when it comes to using arcs and circles. πŸ˜•
                                  • andybotA Offline
                                    andybot
                                    but fine is not exact... that's the whole point isn't it.
                                      jason_maranto
                                      Yes, but I am getting down into 1000ths of a degree on that rotation -- I'm not sure how much more precise it can be without being fully automated... we humans tend to fudge it, but computers can go much more precise in practice -- regardless, you will never build something with wood that will be more precise than what we are doing here. So I think any of these are decent enough for most users... after all this isn't meant to be an engineering program.
                                      Let me put it to you another way, when I do a solid operation (unite/outer shell) there is no gap or extra faces -- it's perfect -- and I think that is about as good of a precision as you are going to get from SketchUp.
                                      Here's the file check for yourself: challenge_altfinal.skp
                                      How I got there: challenge_alt2.jpg
                                      Best,
                                      Jason.
                                        jeff hammond
                                        that's fine and as i said earlier, there are plenty of ways to get it 'close enough' for construction purposes..
                                        the challenge though, at least for this thread, is to get it 100% perfect..
                                        and if you give up at 'close enough' then you'll quit exploring ways to make it precise πŸ˜‰
                                        so while a 100% solution to this challenge isn't totally necessary for me to get a dimension for a cut-list, a 100% solution is necessary to relax the πŸ€“ in some people..
                                        dotdotdot
                                        • pbacotP Offline
                                          Jason may have a point about the precision. The idea is that in doing work that requires this precision (such as survey), where close can give results further out that are way off-- would you EVER be using SU anyway?
                                          Jason you mention entering the rotation manually. Where do you get the angle from? I guess, on the other hand, I think a failsafe technique was sought rather than a function of someone's eyeball ability and time available (which we seem to have ample between us... πŸ˜• )
                                            Problem is that tiny fractions of inaccuracy can very easily cascade into the rest of the model where you start getting issues. Ever so often when I import DWG files I end up with lots of issues where things are nearly square, nearly perpendicular etc. Initially SU treats them as "good enough" bug eventually this inaccuracy creeps over to the point where SU doesn't treat them as square and parallel. In worst scenarios I get models where splitting faces creates duplicate overlapping faces. That's why I don't like settling for "good enough"...
                                            • 6
                                            • 7
                                            • 8
                                            • 16
                                            • 17
                                            • 6 / 17
