    Mini-challenge
    328 Posts 26 Posters 99.4k Views 26 Watching
      you can find all the info of the hypotenuse (green) in a variety of ways .. (for instance, a^2 + b^2 = c^2 to get its length.. you'll know a & b in this case… then trig for the angles)
      that hypotenuse is also the the hypotenuse of the un-trimmed board (red).. so you know the board width and the length of its hypotenuse which means you can get all other angles and lengths..
      I was suspecting something like that - but my trigonometry knowledge was all too poor that I dared place bets on it.
      for whatever reason, i still think there might be a way to do it in sketchup itself.. maybe jean L can come up with something
      I also wonder this - but I also fear it might - due to lack of true arcs.
      Where is Simon Le Bon btw..?
      • jeff hammondJ
        SOH CAH TOA πŸ˜„
        that's one of the things that seemed to stick with me after leaving school..
        Sine = Opposite/Hypotenuse
        Cosine = Adjacent/Hypotenuse
        Tangent = Opposite/Adjacent
          That stuck with me, too. I can't remember who I took to prom, though.
            Trouble is that I don't even remember what to use of this. I'm really annoying - I always have to look up this stuff, reading for a while, whenever I need to do such work with my plugins. ...which, when you place plugins for 3D software... ...I really should be knowing this... 😳
              @jason_maranto said:
              Well, I figured out some of the accuracy issue on my last approach -- a bit of user error on my part since I was rotating the guidepoint to the wrong place and also the accuracy setting of the rotate tool was not set high enough... actually this still isn't exactly accurate (rotated to 45.6085) but it's pretty close now.
              Try with the posts further apart - then you'll catch accuracy issue much easier. When it's close to 45 degrees it's harder to spot.
              • jason_marantoJ
                jason_maranto
                @Jeff - I checked every aspect of interacting with a DC, it shows nothing for me.
                Edit -- Gotcha, you have to actually open the model instead of bringing it in as a component.
                Best,
                Jason.
                • jeff hammondJ
                  oh man.. that reminds me of some problem with sharing dynamic components.. are you directly opening the file i posted or are you bringing it in to an existing model?
                  you have to just open the file i posted then the options should be available..
                  (or something like that.. ❓ i remember having problems with bringing in DCs from the warehouse into existing models and none of the options were available.)
                  • jeff hammondJ
                    ha.. i always figured you ruby gurus were math wizards.. πŸ˜„
                    nice to know you're sitting around looking things up on a per case basis like the rest of us πŸ˜‰
                      You really don't need to muddle around with math too much when making plugins for SketchUp. Their API is doing lots of the heavy work. I don't even fully understand the transformation matrix - though reading up on that now.
                      I do that for everything I do - always. Simply because I like to know I'm doing stuff correct and efficient.
                      • jason_marantoJ
                        jason_maranto
                        This method still works as expected no matter the distance -- the problem is just that the rotate tool is not precise enough to put the guidepoint exactly where it should be.
                        @Jeff -- yeah, sorry my habit is to bring them into a model via the component browser, so it was my fault.
                        Best,
                        Jason.
                        • gillesG
                          gilles
                          I 've found a tricky way.
                          Mini-challenge.skp
                          • jeff hammondJ
                            πŸ˜†
                            (I don't think I even went to prom.. maybe)
                            • jeff hammondJ
                              really? sweet!
                              I'm on a phone now so I can't see it but the suspense is killing me πŸ˜„
                              can anyone verify?
                              • jason_marantoJ
                                jason_maranto
                                Wow, that is tricky... I never would have approached it that way.
                                What gave you the answer?
                                Best,
                                Jason.
                                • andybotA
                                  andybot
                                  Nice one! works for me!
                                  • gillesG
                                    gilles
                                    I dont even know, just an intuition.
                                    So do I won something? πŸ’š
                                      Yes - the honor of authoring the next challenge! πŸ˜„
                                        Unfortunately - the lines are not parallel:
                                        • jeff hammondJ
                                          [attachment=0:1xhfujx7]<!-- ia0 -->Accuracy.png<!-- ia0 -->[/attachment:1xhfujx7]
                                          bah!
                                          I was hoping gilles nailed it
                                          • andybotA
                                            andybot
                                            What's missing? I redid it from scratch. I would suggest drawing a guide-line inferenced perpendicular to the new diagonal lines. (I group the newly drawn diagonals so I can rotate exactly to the perpendicular.)
                                            diagonal1.skp
                                            • 16
                                            • 17
                                            • 6 / 17
