    ๐Ÿ›ฃ๏ธ Road Profile Builder | Generate roads, curbs and pavements easily Download
    Mini-challenge
    328 Posts 26 Posters 31.4k Views 26 Watching
      Charlie__V
      I took one more stab at it...........hopefully more worthy than my first attempt.
      Please see attached SKP's
      Charlie
      hey Charlie.. that's gilles' second (i think second) solution.. it does get it very very close and to me, it's acceptably close since i'll be working in inches like you.. if you tried that while working in metric with the highest precision setting allowed in sketchup then the error would show up..
      basically, you rotate the end to 90ยบ which is fine and what needs to happen.. however, when you rotate the other end to 90ยบ it throws off the first end's 90ยบ..
      Apologies to Gilles ๐Ÿ˜ณ ..............somehow I missed that.......I now see it on pg 7.... ๐Ÿ˜ฒ
      And thanks Jeff for pointing that out.
      Charlie
      • gillesG Offline
        gilles
        Be my guest.
          Charlie__V
          Oh, and Jeff...........thanks for binging this to light.
          A few months ago I was working on a Zipline project.......and making all the X bracing was making me nuts.
          I was "brute forcing it" as you say. (see attached)
          Charlie
          Tower3
          • jeff hammondJ Offline
            jeff hammond
            Charlie
            wow!.. that's a perfect drawing to show to the developers as a case for why this needs to be fixed in sketchup..
            โ˜€
            [edit] and really? you're building ziplines that high? looks fun. ๐Ÿ˜„
            dotdotdot
              The last Fredo method (some simple indeed) without plug gives with apparently no problem of top tangency vertices โ˜€
              1.3239127 Nurbs (height of brace cut vertically) Pilars are 1 * 1 * 10 , brace 1 * 1 * x : unity meter
              1.323908 SU
              13.2391273 Nurbs (length of brace between the pilars)
              13.239127 SU
              14.1421356 Nurbs diagonal
              14.142136 Su
              Does this acceptable ? Accurate or not? ๐Ÿ˜‰
              PS
              (i don't reload the Fredo's file due V8 against V6 ๐Ÿ˜‰ So remake my own version of Fredo's Method! ๐Ÿ˜„
              jeff_fredo.skp
                Charlie__V
                โ˜€
                Jeff,
                I composed a longer/detailed reply...........but? I got timed out I guess.
                So, in short........yes........towers for the ZL are high here (~90' AFG)..because the grade is relatively flat like pancake. (contours @ 1' intervals are typical).
                Attached screenshot depicts my participation in the project. (plan/execute pre assembly components @ grade)...............hoist by crane to place.
                Beast,
                Charlie
                • fredo6F Offline
                  fredo6
                  Unfortunately, although the method is mathematically correct, it suffers from the lack of precision of Sketchup for rotation and parallelism of guides (even with circles of 512 segments).
                  One way to check that is to split the right post and the board and check the intersectio. As shown in the video, it may not be clean in certain cases.
                  So you need an extra step, with the Move tool, to adjust the intersection. You can do this step accurately because the SU Move tools inferences differently the intersection points (cross) and the endpoints (circular dot).
                  Strangely, Ruby does not suffer this inaccuracy issue and gives a correct intersection, although the FredoScale Rotate script uses the same method (i.e. calculate the offset angle and substract it to the rotation angle).
                  Fredo
                  • fredo6F Offline
                    fredo6
                    This mini challenge gave me an interesting idea. Thanks Jeff.
                    I will introduce an option in FredoScale for the tools using rotation, in particular the Free Rotate tool (but also Twist and Rotate in Box).
                    Basically, after you define the plan of rotation and base direction, you will click an extra target point anywhere in the model. This target point, and actually the parallel to the base direction passing through this point will be used as inference guide instead of the base direction.
                    As I did not want to make a separate tool, the convention is that when you click the point for the base direction, you release after 1 second (kind of long click). Then you'll have the opportunity to click the target point as a red cross (in the Fee Rotate tool, you can also toggle this function via Ctrl Alone).
                    Indeed this is a plugin solution to the challenge, but I am not sure there is a pure geometrical solution with just the native standard SU Tools.
                    If you wish to try in advance of releasing, just drop the file Lib6Protractor.rb attached to this post into the LIBFREDO6_Dir_44 folder.
                    Fredo
                    • fredo6F Offline
                      fredo6
                      For info, I just published the script updates for supporting the two problems featured in this mini challenge. See this post for detail and video.
                      This comes in FredoScale, but you just need to download LibFredo6 4.5a.
                      Fredo
                      • utilerU Offline
                        utiler
                        You are a crazy man, Fredo!!!!!
                          Yep! ๐Ÿ˜Ž
                          Classieux! ๐Ÿ‘
                          And no problem in the Big Zoom! โ˜€
                          1.323913m SU
                          http://forums.sketchucation.com/download/file.php?id=87799
                            Charlie__V
                            Bravo Fredo..............Bravo!
                            Thanks lots,
                            Charlie
                              jeff hammond
                              2014 bump
                              dotdotdot
                                @jeff hammond said:
                                2014 bump
                                why are you bumping this, Jeff?
                                  jeff hammond
                                  because you can solve the challenge with su2014
                                  dotdotdot
                                    Oh. By using the new Arc tool.
                                      jeff hammond
                                      right. we finally have a way to natively get a rotated snap point.
                                      next step, incorporate the same inferencing into the rotate tool ๐Ÿ˜‰
                                      (but just having it in the arc tool is fine by me.. I've been wishing for it since maybe 2004 ๐Ÿ˜„ )
                                      dotdotdot
                                        Charlie__V
                                        @jeff hammond said:
                                        Buzzinga! ๐Ÿ˜Ž
                                        C
                                        • Wo3DanW Offline
                                          Wo3Dan
                                          @jeff hammond said:
                                          right. we finally have a way to natively get a rotated snap point. ...
                                          Is it really that accurate? I can't get it to work. If I zoom in I can still see a new endpoint (second end of arc) not being on the edge inside a group I "rotated" to(=pulled the arc to.
                                          • Wo3DanW Offline
                                            Wo3Dan
                                            @wo3dan said:
                                            Is it really that accurate? I can't get it to work. If I zoom in I can still see a new endpoint (second end of arc) not being on the edge inside a group I "rotated" to(=pulled the arc to).
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
