    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 586.7k Views 102 Watching
    • fredo6F Offline
      fredo6
      Maybe you can PM me the model so that I see if this is related to ThruPaint or to your machine configuration.
        Ahmed0007
        hi fredo6
        i'm making a tutorial about your this plugin but i think i found bug.
        it's not painting Dimensions in sketchup 2018-19
        what is the solution.
        Video
        Help.skp
        • fredo6F Offline
          fredo6
          @ahmed0007 said:
          hi fredo6
          It's just a missing feature. Not sure if there is a value in this (versus using the native Paint tool).
          Fredo
            Ahmed0007
            @fredo6 said:
            @ahmed0007 said:
            hi fredo6
            Fredo
            ok.
            thanks for reply.
              chaosaic
              @fredo6 said:
              @chaosaic,
              Difficult to tell what is the problem.
              Could you indicate which UV mode you use (Natural, Projection, QuadMesh) and if you have a problem of performance in all modes.
              Also, what kind of texture do you use? Is it a heavy image?
              after few days of searching and testing , I believe I have found the problem.
              at least the huge one of them.
              when outliner tray is expanded , if the file contains high poly geometry , whether its hidden or not (but geometry in invisible layer not in this case),
              painting UV and using of visual mode will be extremly lag(I'm not sure if this happen in my PC only).
              anyway , really appreciate that you take your time to answer my question patiently.
              and again , great plug-in.
              • fredo6F Offline
                fredo6
                For info, I made a change in FredoTools 3.4a to keep performance OK when outliner is open.
                So if you wish to test if it works in your case...
                Fred0
                  chaosaic
                  Fred0
                  I have just test ThruPaint in FredoTools 3.4a.
                  When outliner tray is opened , painting and adjusting speed is almost the same as its not open.
                  Outliner problem just like mystery to me and you just solve it πŸ˜†
                  As a newbie I want to ask if there's a way to export a 3dsmax model's UV to sketchup?
                  I hvae a 3dsmax model already has it's own UV map, then I export it as .obj, import to WrapR check its the same as 3dsmax model, then import UV.obj by SketchUV tools, but not working.
                  • V Offline
                    Vicente122334
                    Hey Fredo6!
                    So, I was messing around with Thrupaint trying to texture a curved and "Z axis" road and when I tried to texture it, The section where the road is straight and curved is just diferent (deformed) like in the image I just sent...
                    Is there any way I can solve this? I've been searching for almost a week, thanks!
                    • fredo6F Offline
                      fredo6
                      @vicente122334 said:
                      Hey Fredo6!
                      Difficult to tell without the model.
                      In general, you should do all the segments of the road in one go.
                        dedmin
                        Hey Fredo6!
                        • V Offline
                          Vicente122334
                          Hey Fredo6!
                          Hello! Thank you so much for replying!
                          I actually manage to find the solution, I just had to triangulate and I also did what you said in your post, I did all the road together. I actually have another issue but I don't think this one is solvable, I don't know... when the curve starts in my road, the part of the texture on the left side scales up way more than the one on the right side. Is it possible to keep both at the same scale?
                          Thanks for reading! I will also send the sketch file this time.
                          Untitled14.skp
                          • fredo6F Offline
                            fredo6
                            Stretching of the texture is inevitable in the rounding with the way Sketchup handles texture adjustment. There is nothing you can really do about it, even if you manage it manually with the pins.
                            Fredo
                              Ahmed0007
                              Complete Tutorial of Fredo ThruPaint
                              https://youtu.be/db3KAv0-ATI
                              • fredo6F Offline
                                fredo6
                                Thank you very much. Very complete and didactic. Congratulations.
                                I inserted the video in the main post of this thread.
                                Fred
                                PS: You should post on SketchUp Forum too.
                                  Ahmed0007
                                  Fred
                                  Thank you so much πŸ˜„
                                  • summerson1990S Offline
                                    summerson1990
                                    Hi! Can ThruPaint snap to guidelines or geometry when working in visual edition mode to align texture perfectly as native texture position tool does it? Look my screenshot
                                    • fredo6F Offline
                                      fredo6
                                      Not obvious, but probably feasible.
                                        summerson1990
                                        So could you please say how to make it possible to snap? Sometimes it seems like something close to snapping is working but I didn't realized yet in what cases and how exactly it does. Thanks!
                                        • fredo6F Offline
                                          fredo6
                                          I just say that this is not supported in the current version. So I would need to make the change.
                                          Fredo
                                            summerson1990
                                            Fredo
                                            Ok, as you will do it it will be very useful. Thank you!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
