    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 634.0k Views 102 Watching
    • pbacotP
      Can someone demonstrate the proper way to paint cube with perspective or quad painting on it? I thought this was working before. Now I cannot do it. Sometimes if I remove two faces, paint the remainder with the quad setting and add the faces back it works.
      • fredo6F
        A cube cannot be painted in Quad mesh, as this is not a quad mesh. At least one of the face will not be in continuity, unless your texture is perfectly symmetrical in U and V. And if so, use the Natural mode.
        • pbacotP
          • C
            chaosaic
            hello . I'm kind of beginner of sketchup and your wonderful plug-in.
            now I have some serious problem using Thrupaint.
            The main problem is super slow whenever I paint UV map or adjust UV map(visual editor or simply use arrow key)
            in every kind of furface(probably plain,non curve surface is the only kind that's still work normally)
            288 faces sphere is slow(around 30sec),74 faces cylindrical is slow.
            even 6x6 grid rectangle from sandbox tool takes about 20sec to apply UV map.
            it's just frozen there about 30sec or several minute.
            I have tried : turned off vray extension , turned off fast feedback in OpenGL,
            open ruby console before using Thrupaint(no error) or not using other software beside sketchup.
            still not working.
            the only way I find work better is to delete all other model in the file,just keep the one I want to paint. (but i have keep other model out of my sight,would that be a problem?)
            I'm using : sketchup 2018pro
            intel i7-8700 CPU
            NVIDIA geforce gtx 1060(driver is up to date)
            libfredo6 8.8a
            fredo6 tools 3.3c
            it has great ability to paint UV map.but i have no idea why it seems so unusable in my situation.
            please help if you have some time.
            • fredo6F
              @chaosaic,
              Difficult to tell what is the problem.
              Could you indicate which UV mode you use (Natural, Projection, QuadMesh) and if you have a problem of performance in all modes.
              Also, what kind of texture do you use? Is it a heavy image?
              • C
                chaosaic
                @fredo6 said:
                @chaosaic,
                I have tested natural,quadmesh,projected in simple 146 faces cylindrical(24*6 + 2).
                all three mode take over than 20sec to put on UV map.
                and the visual mode is lag to hell.
                Using the default map in "sketchuv mapping tools"(rainbow-like checker)
                which is like 512x512 pixel?
                I have also try my own texture(1024x1024). still lag.
                If I delete most of other high poly model in the file. still need about 15sec.
                And if I change selection face to visible face,it will down to 5~10sec.
                (but sketchuv mapping tools and native paint bucket is instant operation.)
                • fredo6F
                  Maybe you can PM me the model so that I see if this is related to ThruPaint or to your machine configuration.
                    Ahmed0007
                    hi fredo6
                    i'm making a tutorial about your this plugin but i think i found bug.
                    it's not painting Dimensions in sketchup 2018-19
                    what is the solution.
                    Video
                    Help.skp
                    • fredo6F
                      @ahmed0007 said:
                      hi fredo6
                      It's just a missing feature. Not sure if there is a value in this (versus using the native Paint tool).
                        Ahmed0007
                        @fredo6 said:
                        @ahmed0007 said:
                        hi fredo6
                        ok.
                        thanks for reply.
                        • C
                          chaosaic
                          @fredo6 said:
                          @chaosaic,
                          after few days of searching and testing , I believe I have found the problem.
                          at least the huge one of them.
                          when outliner tray is expanded , if the file contains high poly geometry , whether its hidden or not (but geometry in invisible layer not in this case),
                          painting UV and using of visual mode will be extremly lag(I'm not sure if this happen in my PC only).
                          anyway , really appreciate that you take your time to answer my question patiently.
                          and again , great plug-in.
                          • fredo6F
                            For info, I made a change in FredoTools 3.4a to keep performance OK when outliner is open.
                            So if you wish to test if it works in your case...
                            Fred0
                            • C
                              chaosaic
                              Fred0
                              I have just test ThruPaint in FredoTools 3.4a.
                              When outliner tray is opened , painting and adjusting speed is almost the same as its not open.
                              Outliner problem just like mystery to me and you just solve it 😆
                              As a newbie I want to ask if there's a way to export a 3dsmax model's UV to sketchup?
                              I hvae a 3dsmax model already has it's own UV map, then I export it as .obj, import to WrapR check its the same as 3dsmax model, then import UV.obj by SketchUV tools, but not working.
                              • V
                                Vicente122334
                                Hey Fredo6!
                                So, I was messing around with Thrupaint trying to texture a curved and "Z axis" road and when I tried to texture it, The section where the road is straight and curved is just diferent (deformed) like in the image I just sent...
                                Is there any way I can solve this? I've been searching for almost a week, thanks!
                                • fredo6F
                                  @vicente122334 said:
                                  Hey Fredo6!
                                  Difficult to tell without the model.
                                  In general, you should do all the segments of the road in one go.
                                    dedmin
                                    Hey Fredo6!
                                    • V
                                      Vicente122334
                                      Hey Fredo6!
                                      Hello! Thank you so much for replying!
                                      I actually manage to find the solution, I just had to triangulate and I also did what you said in your post, I did all the road together. I actually have another issue but I don't think this one is solvable, I don't know... when the curve starts in my road, the part of the texture on the left side scales up way more than the one on the right side. Is it possible to keep both at the same scale?
                                      Thanks for reading! I will also send the sketch file this time.
                                      Untitled14.skp
                                      • fredo6F
                                        Stretching of the texture is inevitable in the rounding with the way Sketchup handles texture adjustment. There is nothing you can really do about it, even if you manage it manually with the pins.
                                          Ahmed0007
                                          Complete Tutorial of Fredo ThruPaint
                                          https://youtu.be/db3KAv0-ATI
                                          • fredo6F
                                            Thank you very much. Very complete and didactic. Congratulations.
                                            I inserted the video in the main post of this thread.
                                            Fred
                                            PS: You should post on SketchUp Forum too.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
