    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 634.0k Views 102 Watching
    • fredo6F
      @chaosaic,
      Difficult to tell what is the problem.
      Could you indicate which UV mode you use (Natural, Projection, QuadMesh) and if you have a problem of performance in all modes.
      Also, what kind of texture do you use? Is it a heavy image?
      • C
        chaosaic
        @fredo6 said:
        @chaosaic,
        I have tested natural,quadmesh,projected in simple 146 faces cylindrical(24*6 + 2).
        all three mode take over than 20sec to put on UV map.
        and the visual mode is lag to hell.
        Using the default map in "sketchuv mapping tools"(rainbow-like checker)
        which is like 512x512 pixel?
        I have also try my own texture(1024x1024). still lag.
        If I delete most of other high poly model in the file. still need about 15sec.
        And if I change selection face to visible face,it will down to 5~10sec.
        (but sketchuv mapping tools and native paint bucket is instant operation.)
        • fredo6F
          Maybe you can PM me the model so that I see if this is related to ThruPaint or to your machine configuration.
            Ahmed0007
            hi fredo6
            i'm making a tutorial about your this plugin but i think i found bug.
            it's not painting Dimensions in sketchup 2018-19
            what is the solution.
            Video
            Help.skp
            • fredo6F
              @ahmed0007 said:
              hi fredo6
              It's just a missing feature. Not sure if there is a value in this (versus using the native Paint tool).
                Ahmed0007
                @fredo6 said:
                @ahmed0007 said:
                hi fredo6
                ok.
                thanks for reply.
                • C
                  chaosaic
                  @fredo6 said:
                  @chaosaic,
                  after few days of searching and testing , I believe I have found the problem.
                  at least the huge one of them.
                  when outliner tray is expanded , if the file contains high poly geometry , whether its hidden or not (but geometry in invisible layer not in this case),
                  painting UV and using of visual mode will be extremly lag(I'm not sure if this happen in my PC only).
                  anyway , really appreciate that you take your time to answer my question patiently.
                  and again , great plug-in.
                  • fredo6F
                    For info, I made a change in FredoTools 3.4a to keep performance OK when outliner is open.
                    So if you wish to test if it works in your case...
                    Fred0
                    • C
                      chaosaic
                      Fred0
                      I have just test ThruPaint in FredoTools 3.4a.
                      When outliner tray is opened , painting and adjusting speed is almost the same as its not open.
                      Outliner problem just like mystery to me and you just solve it πŸ˜†
                      As a newbie I want to ask if there's a way to export a 3dsmax model's UV to sketchup?
                      I hvae a 3dsmax model already has it's own UV map, then I export it as .obj, import to WrapR check its the same as 3dsmax model, then import UV.obj by SketchUV tools, but not working.
                      • V
                        Vicente122334
                        Hey Fredo6!
                        So, I was messing around with Thrupaint trying to texture a curved and "Z axis" road and when I tried to texture it, The section where the road is straight and curved is just diferent (deformed) like in the image I just sent...
                        Is there any way I can solve this? I've been searching for almost a week, thanks!
                        • fredo6F
                          @vicente122334 said:
                          Hey Fredo6!
                          Difficult to tell without the model.
                          In general, you should do all the segments of the road in one go.
                            dedmin
                            Hey Fredo6!
                            • V
                              Vicente122334
                              Hey Fredo6!
                              Hello! Thank you so much for replying!
                              I actually manage to find the solution, I just had to triangulate and I also did what you said in your post, I did all the road together. I actually have another issue but I don't think this one is solvable, I don't know... when the curve starts in my road, the part of the texture on the left side scales up way more than the one on the right side. Is it possible to keep both at the same scale?
                              Thanks for reading! I will also send the sketch file this time.
                              Untitled14.skp
                              • fredo6F
                                Stretching of the texture is inevitable in the rounding with the way Sketchup handles texture adjustment. There is nothing you can really do about it, even if you manage it manually with the pins.
                                  Ahmed0007
                                  Complete Tutorial of Fredo ThruPaint
                                  https://youtu.be/db3KAv0-ATI
                                  • fredo6F
                                    Thank you very much. Very complete and didactic. Congratulations.
                                    I inserted the video in the main post of this thread.
                                    Fred
                                    PS: You should post on SketchUp Forum too.
                                      Ahmed0007
                                      Fred
                                      Thank you so much πŸ˜„
                                      • summerson1990S
                                        summerson1990
                                        Hi! Can ThruPaint snap to guidelines or geometry when working in visual edition mode to align texture perfectly as native texture position tool does it? Look my screenshot
                                        • fredo6F
                                          Not obvious, but probably feasible.
                                          • summerson1990S
                                            summerson1990
                                            So could you please say how to make it possible to snap? Sometimes it seems like something close to snapping is working but I didn't realized yet in what cases and how exactly it does. Thanks!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
