    [Plugin] SketchUV - now free
    176 Posts 62 Posters 151.7k Views 62 Watching
    • ely862meE Offline
      ely862me
      I am sorry I have not explained myself better .
      By connecting the paths I meant to create a surface between them.
      The impediment is that after you select one path you can't select another one. In this case I select one path with the Path Select tool then I hold CTRL and take the Select tool from Sketchup and select the segments one by one(which is very hard and time consuming).
      Long story short : Take Path Select Tool and select a path then hold CTRL and select as many paths as you want !(This is what I think it will be very useful!)
      Thank you!
      Elisei (sketchupper)
      Come and See EliseiDesign
      • charly2008C Offline
        charly2008
        Hello,
        Is there a way to correct the distortion shown below tool with a UV tool or is the error in the map projection?
        Thanks for any help.
        Untitled.skp
        • FrederikF Offline
          Frederik
          It looks like it's the map, which isn't good enough... 😐
          Here's my attempt with a map from JHT's Planetary Pixel Emporium...
          Earth-model.skp
          Cheers
          Kim Frederik
            charly2008
            Hi Kim,
            thank you for your help and your effort. Also thanks for this link.
            Charly
            • SwissmountainS Offline
              Swissmountain
              Hello and thank you for this much needed plugin.
              I am rendering in Modo and need to export my models.
              I notice that each polygon gets assigned its own material, creating hundreds of materials and making the export near impossible.
              Is this how the plugin is intended to work?
              Cogito ergo dum-di-dum
              • W Offline
                Whaat
                Sorry for the late reply.
                You need to use the Triangulate feature in SketchUV prior to exporting in order to reduce the number of exported materials. This is explained in the SketchUV tutorials.
                Dale
                • cottyC Offline
                  cotty
                  Does anyone have problems with this plugin and SU14?
                  my SketchUp gallery
                  • E Offline
                    Extractor
                    Yes, for example errors in the Ruby Console when using a spherical map. I wrote an e-mail to D. Martens and he replied that there will be an update in a few weeks.
                    • soloS Offline
                      solo
                      Me, I was looking for an updated version.
                      I need this tool to work with SU 2014
                      http://www.solos-art.com
                      • cottyC Offline
                        cotty
                        As Extractor wrote a solution seems to be on the way...
                        my SketchUp gallery
                        • W Offline
                          Whaat
                          Updated version available on Extension Warehouse.
                          SketchUp Extension Warehouse
                          Your library of custom third-party extensions created to optimize your SketchUp workflow.
                          (extensions.sketchup.com)
                          • soloS Offline
                            solo
                            • cottyC Offline
                              cotty
                              my SketchUp gallery
                              • FrederikF Offline
                                Frederik
                                Respect, Dale...
                                Cheers
                                Kim Frederik
                                  Got a donation link Dale? This plugin well deserves donations!
                                  • romboutR Offline
                                    rombout
                                    I got a lot of erros when i export a model to blender and than back. Most of the times i get errors on faces which cant be mapped. The model is kind of a mess, triangles and quads together. Do i need to fix all of this first?
                                      Have no quads on export.
                                      Blenders obj exporter doesn't place nice with SketchUV.
                                      There's the ability to import blender quads as obj with QuadFace Tools.
                                      • romboutR Offline
                                        rombout
                                        That seems like a dirty solution. There's a quad texture in this plugin than why cant it handle quads correct, making it triangles makes unnecessary big. Isnt there a other solution
                                          Do some tests on exporting obj from blender.
                                          You'll see that non planar quad faces are subdivided and not triangulated.
                                          So whilst these plugins support the QuadFace convention it doesn't work both ways unless you force it.
                                          The other solution which is faster is to stay entirely in Blender.
                                          • ToboboT Offline
                                            Tobobo
                                            Ok so I have had a read through the thread and it doesn't seem like anyone is dumb enough to try what I want to do... 😳
                                            I want to create a Icosahedron (triangular sided) globe. So I choose the spherical mapping and the UV maps appear to be ok but when I put the globe texture on the poles aren't quite right.
                                            Is it because there aren't enough faces to map to? Would sub dividing help? or is it too low poly?
                                            Here are the screen shots and skippy.
                                            Thanks in advance
                                            Icosahedron.skp
                                            Toby
                                            Philippians 4:13
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 7 / 9
