    [Plugin] SketchUV - now free
    176 Posts 62 Posters 169.5k Views 62 Watching
    • charly2008C Offline
      charly2008
      Hello,
      Is there a way to correct the distortion shown below tool with a UV tool or is the error in the map projection?
      Thanks for any help.
      Untitled.skp
      • FrederikF Offline
        Frederik
        It looks like it's the map, which isn't good enough... 😐
        Here's my attempt with a map from JHT's Planetary Pixel Emporium...
        Earth-model.skp
        Cheers
        Kim Frederik
          charly2008
          Hi Kim,
          thank you for your help and your effort. Also thanks for this link.
          Charly
          • SwissmountainS Offline
            Swissmountain
            Hello and thank you for this much needed plugin.
            I am rendering in Modo and need to export my models.
            I notice that each polygon gets assigned its own material, creating hundreds of materials and making the export near impossible.
            Is this how the plugin is intended to work?
            Cogito ergo dum-di-dum
            • W Offline
              Whaat
              Sorry for the late reply.
              You need to use the Triangulate feature in SketchUV prior to exporting in order to reduce the number of exported materials. This is explained in the SketchUV tutorials.
              Dale
              • cottyC Offline
                cotty
                Does anyone have problems with this plugin and SU14?
                my SketchUp gallery
                • E Offline
                  Extractor
                  Yes, for example errors in the Ruby Console when using a spherical map. I wrote an e-mail to D. Martens and he replied that there will be an update in a few weeks.
                  • soloS Offline
                    Me, I was looking for an updated version.
                    I need this tool to work with SU 2014
                    • cottyC Offline
                      cotty
                      As Extractor wrote a solution seems to be on the way...
                      my SketchUp gallery
                      • W Offline
                        Whaat
                        Updated version available on Extension Warehouse.
                        ERROR: The request could not be satisfied
                        (extensions.sketchup.com)
                        • soloS Offline
                          • cottyC Offline
                            cotty
                            my SketchUp gallery
                            • FrederikF Offline
                              Frederik
                              Respect, Dale...
                              Cheers
                              Kim Frederik
                                Got a donation link Dale? This plugin well deserves donations!
                                • romboutR Offline
                                  rombout
                                  I got a lot of erros when i export a model to blender and than back. Most of the times i get errors on faces which cant be mapped. The model is kind of a mess, triangles and quads together. Do i need to fix all of this first?
                                    Have no quads on export.
                                    Blenders obj exporter doesn't place nice with SketchUV.
                                    There's the ability to import blender quads as obj with QuadFace Tools.
                                    • romboutR Offline
                                      rombout
                                      That seems like a dirty solution. There's a quad texture in this plugin than why cant it handle quads correct, making it triangles makes unnecessary big. Isnt there a other solution
                                        Do some tests on exporting obj from blender.
                                        You'll see that non planar quad faces are subdivided and not triangulated.
                                        So whilst these plugins support the QuadFace convention it doesn't work both ways unless you force it.
                                        The other solution which is faster is to stay entirely in Blender.
                                        • ToboboT Offline
                                          Tobobo
                                          Ok so I have had a read through the thread and it doesn't seem like anyone is dumb enough to try what I want to do... 😳
                                          I want to create a Icosahedron (triangular sided) globe. So I choose the spherical mapping and the UV maps appear to be ok but when I put the globe texture on the poles aren't quite right.
                                          Is it because there aren't enough faces to map to? Would sub dividing help? or is it too low poly?
                                          Here are the screen shots and skippy.
                                          Thanks in advance
                                          Icosahedron.skp
                                          Toby
                                          Philippians 4:13
                                            That look about right to me.
                                            Tri's and poles are hard for any mapping method.
                                            • 7 / 9
