    [Plugin] SketchUV - now free
    176 Posts 62 Posters 161.9k Views 62 Watching
    • FrederikF Offline
      Frederik
      It looks like it's the map, which isn't good enough... 😐
      Here's my attempt with a map from JHT's Planetary Pixel Emporium...
      Earth-model.skp
      Cheers
      Kim Frederik
      • charly2008C Offline
        charly2008
        Hi Kim,
        thank you for your help and your effort. Also thanks for this link.
        Charly
        • SwissmountainS Offline
          Swissmountain
          Hello and thank you for this much needed plugin.
          I am rendering in Modo and need to export my models.
          I notice that each polygon gets assigned its own material, creating hundreds of materials and making the export near impossible.
          Is this how the plugin is intended to work?
          Cogito ergo dum-di-dum
          • W Offline
            Whaat
            Sorry for the late reply.
            You need to use the Triangulate feature in SketchUV prior to exporting in order to reduce the number of exported materials. This is explained in the SketchUV tutorials.
            Dale
            • cottyC Offline
              cotty
              Does anyone have problems with this plugin and SU14?
              my SketchUp gallery
              • E Offline
                Extractor
                Yes, for example errors in the Ruby Console when using a spherical map. I wrote an e-mail to D. Martens and he replied that there will be an update in a few weeks.
                • soloS Offline
                  Me, I was looking for an updated version.
                  I need this tool to work with SU 2014
                  • cottyC Offline
                    cotty
                    As Extractor wrote a solution seems to be on the way...
                    my SketchUp gallery
                    • W Offline
                      Whaat
                      Updated version available on Extension Warehouse.
                      SketchUp Extension Warehouse
                      Your library of custom third-party extensions created to optimize your SketchUp workflow.
                      (extensions.sketchup.com)
                      • soloS Offline
                        πŸ‘ πŸ˜„
                        • cottyC Offline
                          cotty
                          πŸŽ‰ πŸ‘
                          my SketchUp gallery
                          • FrederikF Offline
                            Frederik
                            πŸ˜„ πŸ‘
                            Respect, Dale...
                            Cheers
                            Kim Frederik
                              Got a donation link Dale? This plugin well deserves donations!
                              • romboutR Offline
                                rombout
                                I got a lot of erros when i export a model to blender and than back. Most of the times i get errors on faces which cant be mapped. The model is kind of a mess, triangles and quads together. Do i need to fix all of this first?
                                  Have no quads on export.
                                  Blenders obj exporter doesn't place nice with SketchUV.
                                  There's the ability to import blender quads as obj with QuadFace Tools.
                                  • romboutR Offline
                                    rombout
                                    That seems like a dirty solution. There's a quad texture in this plugin than why cant it handle quads correct, making it triangles makes unnecessary big. Isnt there a other solution
                                      Do some tests on exporting obj from blender.
                                      You'll see that non planar quad faces are subdivided and not triangulated.
                                      So whilst these plugins support the QuadFace convention it doesn't work both ways unless you force it.
                                      The other solution which is faster is to stay entirely in Blender.
                                      • ToboboT Offline
                                        Tobobo
                                        Ok so I have had a read through the thread and it doesn't seem like anyone is dumb enough to try what I want to do... 😳
                                        I want to create a Icosahedron (triangular sided) globe. So I choose the spherical mapping and the UV maps appear to be ok but when I put the globe texture on the poles aren't quite right.
                                        Is it because there aren't enough faces to map to? Would sub dividing help? or is it too low poly?
                                        Here are the screen shots and skippy.
                                        Thanks in advance
                                        Icosahedron.skp
                                        Toby
                                        Philippians 4:13
                                          That look about right to me.
                                          Tri's and poles are hard for any mapping method.
                                          • ToboboT Offline
                                            Tobobo
                                            I'm not so fussed about Antarctica but Greenland isn't quite all there.
                                            Toby
                                            Philippians 4:13
                                            • 7 / 9
