    [Plugin] Edges/Construction Lines Converter V1.3
    25 Posts 13 Posters 29.0k Views 13 Watching
      Michaelv
      Based on the original Xline tool from Rick Wilson
      Copyright 2012 (c) EDGE LLC
      All Rights Reserved.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
      WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
      MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      Unzip and then place Xlinem script and Xlinem folder into the plugin folder.
      This tool is either contextual menu or toolbar activated.
      It will work on preselected entities, as well as allow you to pick them after activation.
      It will transform selected edges into construction lines (stipple can be chosen), and selected construction lines into edges (unless they are infinite) of a particular color (or black).
      By using ALT (Mac) you can opt to also have construction points at the end of these lines.
      To delete construction points, use the standard delete methods
      By using Command (Mac) you can toggle the tool modes:
      Default mode is change edges into construction lines, and vice versa
      The second mode changes the construction line's stipple and the edges' color (it doesn't change their nature).
      The stipple change also works on infinite construction lines.
      In the color change mode it will allow you to change the color of any edge.
      The color and stipple pattern is chosen by right clicking in empty space.
      It will originally ask you if you want to display the edge with color by material (an option, without which you WILL NOT SEE the edge color change, yet it's there. If you choose entity info, you'll see that the color is properly applied, but to display it, you have to change that style option). Once you pick yes, that option is saved with the model. If you pick no it can always be changed later in the style menu box.
      The color and stipple you choose remain throughout your entire session. They don't change if you change tool and come back, but it will revert back to black and standard stipple once you quit SU.
      This script is tested on Mac, but it should work on PC. Let me know otherwise.
      Version 1.0 - 3/30/2012
      Version 1.1 - 3/30/2012 Added color changing
      Version 1.3 - 3/31/2012 Simpler, more logical and much better integration
      Xlinem 1.3.zip
      • mitcorbM Offline
        mitcorb
        Hi, Michael:
        Thanks for sharing this tool.
          jorge2011
          EXCELLENT PLUGIN.
          a query.?
          is possible convert smooth lines to construction lines?
          is possible the option of adding construction points at the ends of the lines?
          You can auto-detect lines with the mouse when I pass over a line?
          thank you very much
          • guanjinG Offline
            guanjin
            Right-click to select the color point of the blank, invalid
            I come from China, is to learn
            • guanjinG Offline
              guanjin
              Right-click to select the color, no response
                Michaelv
                @jorge2011 said:
                EXCELLENT PLUGIN.
                a query.?
                thank you very much
                Smooth line, well I assume that if you view hidden, you can pick them and convert, I'll try.
                Cpoints, done already, use alt
                auto detect, well that would be nice, I don't know how to do yet 😄
                I presume what you mean is highlighting the line as you go over, before clicking to pick it.
                I'll look into it, but I'm working on 1.3 for much better integration too.
                As for no color, I don't know I will look, but mine works, so not sure why.
                  Michaelv
                  It only works when you are in the color change mode (see status line at bottom, and change mode with command key).
                  Works all the time now (in version 1.3)
                    jorge2011
                    thank you very much for this update.
                    "auto detect, well that would be nice, I don't know how to do yet 😄
                    I presume what you mean is highlighting the line as you go over, before clicking to pick it."
                    YES 😄
                    • jeff hammondJ Offline
                      jeff hammond
                      neat. thank you!
                      dotdotdot
                      • Clayton49C Offline
                        Clayton49
                        Hi All,
                        Can anyone confirm if this PLUG-IN works with SU Pro-2014.
                        Over & out,
                        Clayton.
                        Over & out,
                        Clayton.
                        %(#008000)[Trotman & Taylor
                        Architectural Consultants]
                          Works perfectly with the 2014 Make (PC), so I suppose that is the same for the Pro! 💚
                            @clayton49 said:
                            Hi All,
                            Over & out,
                            Clayton.
                            What happens when you try it?
                            • greenskpG Offline
                              greenskp
                              Thank you!
                              Works great! SketchUp 2015!
                              • F Offline
                                function
                                bug on console load 2016
                                C;/Users/user01/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/xLinem.rb;39; warning; class variable access from toplevel
                                C;/Users/user01/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/xLinem.rb;40; warning; class variable access from toplevel
                                  How did you install it? I just installed it in SU2016 using the Extension Store and it works just fine.
                                  • F Offline
                                    function
                                    strange, I always use thomthom's drag and drop - is it possible something else could cause an error like that?
                                      What do you mean you use ThomThom's drag and drop?
                                      I expect you've got the thing installed incorrectly or it would work.
                                      • F Offline
                                        function
                                        thomthom's drop zone installer. still gives me error, also using eneroth's console opener on start, not sure if that has something to do with it
                                          If you've got a bad installation of it, installing it again won't clean it up. At this point you should go to the Plugins folder and remove all traces of this plugin. Then either download the RBZ file and installed it with Install Extension in Preferences>Extensions or navigate to it in the Sketchucation Extension Store and install it with the Install button. Both of those options are sure to install it correctly.
                                          • SketcheldarS Offline
                                            Sketcheldar
                                            Thanks for the plugin!!!, it doesn’t work in sketchup 2024, you can fix it
                                            • 1 / 2
