    [Plugin] Edges/Construction Lines Converter V1.3
    25 Posts 13 Posters 28.9k Views 13 Watching
    • SketcheldarS Offline
      Sketcheldar
      #Corrected code for plugin to work in SU 2024
        @@colorx = "Black"
        @@stipplex = "_"
        def initialize
          @endpoints = false
          @change = false
          @colorlist = String.new
          colorlist = Sketchup::Color.names
          l = colorlist.size
          l = l - 1
          for e in 0..l do
            @colorlist = @colorlist + colorlist[e].to_s + "|" if e != l
            @colorlist = @colorlist + colorlist[e].to_s if e == l
          cflag = false
        def activate
          @model = Sketchup.active_model
          @ents = @model.active_entities
          @sel = @model.selection
          @lines = []
          show_status
          conversion
        def show_status
          statustext = "Edges into \"" + @@stipplex + "\" construction lines and cline to " + @@colorx + " edges (Command)" if !@change
          statustext = "Construction lines into \"" + @@stipplex + "\" clines and edges into " + @@colorx + " edges (Command)" if @change
          statusoption = "; Draw end points (Alt)" if @endpoints
          statusoption = "; Endpoints not drawn (Alt)" if !@endpoints
          status_label = statustext + statusoption
          Sketchup.set_status_text(status_label, SB_PROMPT)
        def conversion
          @model.start_operation "Line Conversion"
          view = @model.active_view
          if !@change
            for e in @sel
              if e.class == Sketchup::Edge
                lstart = e.start.position
                lend = e.end.position
                if @endpoints
                  @ents.add_cpoint lstart
                  @ents.add_cpoint lend
                @ents.add_cline(lstart, lend, @@stipplex)
                @lines.push(e)
              elsif e.class == Sketchup::ConstructionLine
                if e.start && e.end
                  if @endpoints
                  @ents.add_edges(lstart, lend)
                  @ents[-1].material = @@colorx.to_s
                  @ents[-1].find_faces
                  @lines.push(e)
              end # e.class
            end # for e
            if !@lines.empty?
              @lines.each do |e|
                e.erase! if e.valid?
          elsif @change
            for e in @sel
                e.stipple = @@stipplex
                if e.start && e.end
                  if @endpoints
              elsif e.class == Sketchup::Edge
                if @endpoints
                e.material = @@colorx.to_s
              end # e.class
              view.invalidate
            end # for e
          end # @change
          @sel.clear
          @model.commit_operation
        def self.xLine_validate_selection_edge
          Sketchup.active_model.selection.each {|e| return true if e.class == Sketchup::Edge}
          return nil
        def self.xLine_validate_selection_xline
          Sketchup.active_model.selection.each {|e| return true if (e.class == Sketchup::ConstructionLine && e.start && e.end)}
          return nil
        def onKeyDown(key, repeat, flags, view)
          if key == VK_COMMAND  ### Cmd toggles stipples and change
            @change = !@change
          if key == VK_ALT ### Alt toggles end points
            @endpoints = !@endpoints
          show_status
        def onLButtonDown(flags, x, y, view)
          ph = view.pick_helper
          ph.do_pick(x, y)
          best = ph.best_picked
          @sel.add(best) if best
          conversion
        def onRButtonDown(flags, x, y, view)
          cflag = true if @@colorx == "Black"
          list = ["-|.|-.-|_", @colorlist]
          prompt = ["XLine Stipple: ", "Color: "]
          values = [@@stipplex, @@colorx]
          result = inputbox(prompt, values, list, "Change Parameters")
          if result
            @@stipplex = result[0].to_s
            @@colorx = result[1].to_s
            if cflag && @model.rendering_options["EdgeColorMode"] != 0
              choice = UI.messagebox "The edges color will only be visible if you switch to \"display color by material\". Do you want to do this at this time?", MB_YESNOCANCEL
              case choice
              when 6
                @model.rendering_options["EdgeColorMode"] = 0 # sets up styles for Color By material
                cflag = false
              when 7
                cflag = false
            end # if cflag
          end # if result
          show_status
          conversion
        def deactivate(view)
          Sketchup.set_status_text("", SB_PROMPT)
          Sketchup.set_status_text("", SB_VCB_LABEL)
          Sketchup.set_status_text("", SB_VCB_VALUE)
      if !file_loaded?("XLinem.rb")
        UI.add_context_menu_handler do |menu|
          if XLinemTool.xLine_validate_selection_edge
            menu.add_separator
            menu.add_item("Convert to XLine") {Sketchup.active_model.select_tool(XLinemTool.new)}
          elsif XLinemTool.xLine_validate_selection_xline
            menu.add_separator
            menu.add_item("Convert to Edge") {Sketchup.active_model.select_tool(XLinemTool.new)}
      unless file_loaded?(__FILE__)
        cmd = UI::Command.new("xlinem Convert") {Sketchup.active_model.select_tool(XLinemTool.new)}
        cmd.small_icon = File.join(File.dirname(__FILE__), "Xlinem", "Xline_SM.png")
        cmd.large_icon = File.join(File.dirname(__FILE__), "Xlinem", "Xline_LG.png")
        cmd.tooltip = "Construction Line Conversion"
        tb = UI.toolbar("Line Conversion") # Fixed string termination
        tb.add_item(cmd)
        tb.restore
      end```
      TIGT F 2 Replies Last reply Reply Quote 1
      • TIGT Online
        TIG Moderator @Sketcheldar
        @Sketcheldar
        Because you haven't formatted your code properly it's unusable.
        Use the </> button to add the correct 'Code' formatting...
        Which is three ` at the start & end of your code, on a separate line.
        • F Offline
          FlorinAp @Sketcheldar
          @Sketcheldar Something is wrong with this code...!!??
          TIGT 1 Reply Last reply Reply Quote 0
          • TIGT Online
            TIG Moderator @FlorinAp
            @FlorinAp
            That code has never worked.
            The code as presented applies to a Class [XLinemTool] which should be inside a Module.
            No Class is defined.
            There's no RB file to set up the extension as SketchUp loads, and the image PNGs are not in a folder with the main code.
            There's also three trailing ` characters.
            If the missing parts were supplied and the whole lot then packaged in an RBZ file, life would be much easier for every one...
            F 1 Reply Last reply Reply Quote 0
            • F Offline
              FlorinAp @TIG
              @TIG Maybe somebody can do something about it, because right now we have no option to convert construction lines to edges (the reverse it is possible, at least with Curvizard).
              I know only one option (DBur Guide Tools) but it can do only one line at a time....
              • 2 / 2
