    Ugly black junctions
    renderpluginsextensions
    7 Posts 4 Posters 1.5k Views 4 Watching
    • john2J
      john2
      im rendering a building, vray shows black patches at junctions. what should i do? I checked the model but it's fine.
      http://i.imgur.com/besju.jpg
      http://i.imgur.com/3ezPC.jpg
      • eidam655E
        eidam655
        that's IMO either Ambient Occlusion in render settings or a dirt pass in the material.
        I'm using SketchUp 2017, V-Ray 3.4
        • john2J
          john2
          here's my ambient occlusion setting. what is the optimum setting that one should use??
          http://i.imgur.com/ZPp8E.jpg
          rest all are default
          • chonC
            chon
            As eidam655, did you put a dirt diffuse on your material ?
            SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
            • thomthomT
              Reduce your amount. Defaults are 0,8
              • john2J
                john2
                well that works. πŸ˜„ the defaults are OK. do you people use defaults for ambient occlusion.?? i actually needed very sharp lines of edges
                • thomthomT
                  Some times I reduce the amount to 0.4 or 0.6 - depending on model. Rarely need to increase it.
                  Might adjust the radius as well on occasion.
