Ugly black junctions
im rendering a building, vray shows black patches at junctions. what should i do? I checked the model but it's fine.
that's IMO either Ambient Occlusion in render settings or a dirt pass in the material.
here's my ambient occlusion setting. what is the optimum setting that one should use??
rest all are default
As eidam655, did you put a dirt diffuse on your material ?
Reduce your amount. Defaults are 0,8
well that works.
the defaults are OK. do you people use defaults for ambient occlusion.?? i actually needed very sharp lines of edges
Some times I reduce the amount to 0.4 or 0.6 - depending on model. Rarely need to increase it.
Might adjust the radius as well on occasion.
