Simple Artisan examples collection
Is it possible to change the geometry so that there is no pole?
Of course but at times poles are inevitable. Just beware poles cause mesh pinching.
In that example you have 6 edges converging to one point at 4 locations.
If you tweak the proxy to lower the pole from 6 edges to 5 you then end up with 8 poles.
Thanks guys. These will show me how to put together my next chair model.
from Pete's old Model This: Minion thread
Must finish it off first...
hii i want to download full version of artisan plugins pls send me the link or put the file pls i need it... and one thing i already have the plugin but i can't use that plugin.
Here you can (legally) obtain artisan: http://artisan4sketchup.com/
Else, if your post refers to some other (illegal) source of the plugin, be warned that SketchUcation does not tolerate piracy. For the time being, I hope it's only a language misapprehension
Looks like your trial period is over, you can buy a license here: http://artisan4sketchup.com/
edit: oh, Gaieus was faster
I Need your Help. How do I get this quad faces with artisan. I only get this result (see photo below).
Thanks in advance for your help.
Hi charly:
See dialogue on previous page at Friday, August 23 in this thread. Notice how cotty predefined the lines on the baby rattle, also. -
Hi, charly.
See if this helps. I did not use other plugins. Only Artisan. As stated, delete all internal partitions.
An excellent sofa example by ginchius with proxy image and rendered version.
Wow ginchius' models are so convincing! I can imagine just how comfy the sofa is just by looking at the render! Most furniture models looks very static and formal.
very nice. Not so "simple" but a good example if you are looking "where to begin?" on something this complex.
Nice little "poor man's voronoi" workflow by Jeff here.
Good example Cotty
Thera are a few n-gons that I'd get rid of though
Some furniture examples by Alvis, e.g.
Not simple, Simply Mind Boggling!
Nice find, thanks for sharing the link!
(I've added an image as a preview, hope you don't mind)
Just found this useful reference for subdivision proxies. These aren't Sketchup examples, but a lot of the methods should work well with Artisan and help people understand how to approach fairly common shapes.
Register LoginAdvertisement
