    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 463.0k Views 80 Watching
      @max
      That laptop is unique.
      Treasure it
      • CadFatherC
        CadFather
        true... ๐Ÿ˜† and you should see it now!
        PS. easy with your psychic powers.... (i sold it today) ๐Ÿ˜ฎ
          They say there's one born every minute.
          • CadFatherC
            CadFather
            hahaha... not at all mister, this is a beast which should last plenty (unless you jinx it!) ๐Ÿ˜†
            • CadFatherC
              CadFather
              only strange thing i found, the green settings window always pops up on start, even if i uncheck the option. not sure it's supposed to be that way.
              • A
                Anton_S
                It shouldn't show up if you uncheck the "Show on Start" option. I tested it on my Windows 7, SU8, 13, 14, and 15 64bit. Can you give give me your system background, such as OS and SU version?
                • CadFatherC
                  CadFather
                  ok, so that's strange, it happens on all my versions (8, 2014, 2015-x64).
                  i guess you may want to wait if anyone else has the same problem while i investigate further for conflicts etc. win7 64bit.
                  Thanks Anton
                  • A
                    Anton_S
                    Thanks Anton
                    Hmm...
                    I think swo_on_quit observer from the new AMS library doesn't work properly. I will look into it. Just to ensure that other observers work, I would like you to do a simple test:
                    1. Open Window Settings dialog, and use the menu bar option (Menu)Window > Settings > Full Screen to switch SU full screen. See if the dialog updates its radio-button mode.
                    2. Another test, maximize and restore your SketchUp window using the maximize button on the upper right corner of the window. See if the dialog updates its radio-button mode.
                    If the dialog doesn't updates, then there is a problem with the whole observing system in my new library; otherwise, it's just this swo_on_quit observer not working for some...
                    I would appreciate your tests,
                    • CadFatherC
                      CadFather
                      ok, on all tests the radio buttons update properly. this with 2015x64
                      • A
                        Anton_S
                        Phew! It's just the swo_on_quit observer method that doesn't work on all systems. I will investigate.
                        • CadFatherC
                          CadFather
                          phew! ๐Ÿ˜†
                          • A
                            Anton_S
                            I think I know why it isn't working. Basically, when you close the dialog, by default the dialog unregisters the observer, which prevents the swo_on_quit observer method from being triggered. But, just to ensure the swo_on_quit is working, paste and submit this code into ruby console and quit SketchUp. This should show the 'Works!' message box.
                            class AMSObserverTest; def swo_on_quit; UI.messagebox('Works!'); end; end; AMS;;Sketchup.add_observer(AMSObserverTest.new)
                            • CadFatherC
                              CadFather
                              exactly as you described it - i got a 'works!' button as i quit SU.
                              (on reopening i still got the green bar)
                              • A
                                Anton_S
                                Ghurait! Try the new version!
                                (The test you did was meant to check AMS Library observer, which had nothing to do with changing how AMS Window Settings 4.0.0 worked.)
                                • CadFatherC
                                  CadFather
                                  yeeeeaaa! fantastic Master Anton, works ghurait now! ๐Ÿ˜„ ๐Ÿ‘
                                  • D
                                    dtrarch
                                    ams window dialog stuck.jpgHi Anton
                                    The settings dialog icon from your plugin tries to open the SU program dialog for an instant but closes and just opens your settings.
                                    No way to move to another monitor or make floating.
                                    just a fixed location per my screen clip.
                                    (Your settings is grayed out by screen capture software)
                                    Win 7 pro
                                    SU 2015 pro
                                    Firfox
                                    This is a must have script and thanks thanks thanks.
                                    A fix would sure be appreciated
                                    Dave
                                    • A
                                      Anton_S
                                      I removed the pick and drag feature, just cause I thought upper-right corner of the view was the best location for the dialog. I might re-add it in the next release.
                                      It looks like my plugin tries create a new dialog, but in fact, that's the same dialog with border and caption removed. I will make it do such procedure faster, so it's done before the dialog is set visible.
                                      • D
                                        dtrarch
                                        Anton
                                        The pick-and-drag gang will beg
                                        dtr
                                        • D
                                          dtrarch
                                          Hi Anton
                                          The border and caption (SU)will be needed to drag the plugin.
                                          Also to locate the plugin on another screen.
                                          Dave
                                          • A
                                            Anton_S
                                            @dtrarch said:
                                            Hi Anton
                                            Dave
                                            I won't add the border and caption, cause I think the widows frame doesn't look so good, but I will make the green heading draggable and clippable...
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 14
                                            • 15
                                            • 8 / 15
