    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 422.7k Views 80 Watching
      Anton_S
      @cadfather said:
      only strange thing i found, the green settings window always pops up on start, even if i uncheck the option. not sure it's supposed to be that way.
      It shouldn't show up if you uncheck the "Show on Start" option. I tested it on my Windows 7, SU8, 13, 14, and 15 64bit. Can you give give me your system background, such as OS and SU version?
      • CadFatherC Offline
        CadFather
        ok, so that's strange, it happens on all my versions (8, 2014, 2015-x64).
        i guess you may want to wait if anyone else has the same problem while i investigate further for conflicts etc. win7 64bit.
        Thanks Anton
          Anton_S
          Thanks Anton
          Hmm...
          I think swo_on_quit observer from the new AMS library doesn't work properly. I will look into it. Just to ensure that other observers work, I would like you to do a simple test:
          1. Open Window Settings dialog, and use the menu bar option (Menu)Window > Settings > Full Screen to switch SU full screen. See if the dialog updates its radio-button mode.
          2. Another test, maximize and restore your SketchUp window using the maximize button on the upper right corner of the window. See if the dialog updates its radio-button mode.
          If the dialog doesn't updates, then there is a problem with the whole observing system in my new library; otherwise, it's just this swo_on_quit observer not working for some...
          I would appreciate your tests,
            CadFather
            ok, on all tests the radio buttons update properly. this with 2015x64
              Anton_S
              Phew! It's just the swo_on_quit observer method that doesn't work on all systems. I will investigate.
                CadFather
                phew! πŸ˜†
                  Anton_S
                  I think I know why it isn't working. Basically, when you close the dialog, by default the dialog unregisters the observer, which prevents the swo_on_quit observer method from being triggered. But, just to ensure the swo_on_quit is working, paste and submit this code into ruby console and quit SketchUp. This should show the 'Works!' message box.
                  class AMSObserverTest; def swo_on_quit; UI.messagebox('Works!'); end; end; AMS;;Sketchup.add_observer(AMSObserverTest.new)
                    CadFather
                    exactly as you described it - i got a 'works!' button as i quit SU.
                    (on reopening i still got the green bar)
                      Anton_S
                      Ghurait! Try the new version!
                      (The test you did was meant to check AMS Library observer, which had nothing to do with changing how AMS Window Settings 4.0.0 worked.)
                        CadFather
                        yeeeeaaa! fantastic Master Anton, works ghurait now! πŸ˜„ πŸ‘
                          dtrarch
                          ams window dialog stuck.jpgHi Anton
                          The settings dialog icon from your plugin tries to open the SU program dialog for an instant but closes and just opens your settings.
                          No way to move to another monitor or make floating.
                          just a fixed location per my screen clip.
                          (Your settings is grayed out by screen capture software)
                          Win 7 pro
                          SU 2015 pro
                          Firfox
                          This is a must have script and thanks thanks thanks.
                          A fix would sure be appreciated
                          Dave
                            Anton_S
                            I removed the pick and drag feature, just cause I thought upper-right corner of the view was the best location for the dialog. I might re-add it in the next release.
                            It looks like my plugin tries create a new dialog, but in fact, that's the same dialog with border and caption removed. I will make it do such procedure faster, so it's done before the dialog is set visible.
                              dtrarch
                              Anton
                              The pick-and-drag gang will beg
                              dtr
                                dtrarch
                                Hi Anton
                                The border and caption (SU)will be needed to drag the plugin.
                                Also to locate the plugin on another screen.
                                Dave
                                  Anton_S
                                  @dtrarch said:
                                  Hi Anton
                                  Dave
                                  I won't add the border and caption, cause I think the widows frame doesn't look so good, but I will make the green heading draggable and clippable...
                                    dtrarch
                                    Hi Anton
                                    Good news to be able to drag.
                                    Will it lock to other SU captions ?
                                    Very handy to set a typ screen org for templates.
                                    Here is how I use them in any case.
                                    (in line here)
                                    SU Window Settings is on screen #2
                                    Your plugin should have been part of SU from the very beginning.
                                    Thanks for getting back too.
                                    Dave
                                      Anton_S
                                      4.1.0 has been released!
                                      • Added pick, drag and clip feature to the new dialog.
                                      • Made borders hide faster.
                                      • Added localization to dialog.
                                      Click on green caption to drag the dialog, easy as that...
                                        dtrarch
                                        Anton
                                        V4.1.0 did not drag (or move) green title and would not close menu when arrow was clicked.
                                        SU title hide was still slow.
                                        Show/Hide toolbars and dialogs killed all my on screen settings for both when invoked.
                                        Sorry
                                        Dave
                                          Anton_S
                                          @dtrarch said:
                                          Anton
                                          Sorry
                                          Dave
                                          It works well on my windows 7. What operating system are you using and what internet explorer version?
                                          Edit: I tested on my Windows XP (with IE9) and it doesn't work just like you described. There is not much I can do about compatibility other than retrieving the original version. So, if you use IE9, use the old version which is compatible in SU2014 and below. You need AMS Library 1.0.9 for the old version too. Here are the links:
                                          ams_lib_1.0.9.zip
                                          ams_WindowSetttings_3.8.1.zip
                                            dtrarch
                                            Hi Anton
                                            I have Win 7 pro
                                            SU 2015 pro
                                            (this is the problem SU version)
                                            (Not much else installed)
                                            Tig extrude lines.rb
                                            Wiki tools
                                            Works fine on SU 2014 Pro
                                            Firefox browser most updated
                                            Win Explorer 11 installed
                                            Dave
                                            • 14
                                            • 15
                                            • 8 / 15
