    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 463.1k Views 80 Watching
    • CadFatherC
      CadFather
      ok, so that's strange, it happens on all my versions (8, 2014, 2015-x64).
      i guess you may want to wait if anyone else has the same problem while i investigate further for conflicts etc. win7 64bit.
      Thanks Anton
        Anton_S
        Thanks Anton
        Hmm...
        I think swo_on_quit observer from the new AMS library doesn't work properly. I will look into it. Just to ensure that other observers work, I would like you to do a simple test:
        1. Open Window Settings dialog, and use the menu bar option (Menu)Window > Settings > Full Screen to switch SU full screen. See if the dialog updates its radio-button mode.
        2. Another test, maximize and restore your SketchUp window using the maximize button on the upper right corner of the window. See if the dialog updates its radio-button mode.
        If the dialog doesn't updates, then there is a problem with the whole observing system in my new library; otherwise, it's just this swo_on_quit observer not working for some...
        I would appreciate your tests,
        • CadFatherC
          CadFather
          ok, on all tests the radio buttons update properly. this with 2015x64
            Anton_S
            Phew! It's just the swo_on_quit observer method that doesn't work on all systems. I will investigate.
            • CadFatherC
              CadFather
              phew! πŸ˜†
                Anton_S
                I think I know why it isn't working. Basically, when you close the dialog, by default the dialog unregisters the observer, which prevents the swo_on_quit observer method from being triggered. But, just to ensure the swo_on_quit is working, paste and submit this code into ruby console and quit SketchUp. This should show the 'Works!' message box.
                class AMSObserverTest; def swo_on_quit; UI.messagebox('Works!'); end; end; AMS;;Sketchup.add_observer(AMSObserverTest.new)
                • CadFatherC
                  CadFather
                  exactly as you described it - i got a 'works!' button as i quit SU.
                  (on reopening i still got the green bar)
                    Anton_S
                    Ghurait! Try the new version!
                    (The test you did was meant to check AMS Library observer, which had nothing to do with changing how AMS Window Settings 4.0.0 worked.)
                    • CadFatherC
                      CadFather
                      yeeeeaaa! fantastic Master Anton, works ghurait now! πŸ˜„ πŸ‘
                        dtrarch
                        ams window dialog stuck.jpgHi Anton
                        The settings dialog icon from your plugin tries to open the SU program dialog for an instant but closes and just opens your settings.
                        No way to move to another monitor or make floating.
                        just a fixed location per my screen clip.
                        (Your settings is grayed out by screen capture software)
                        Win 7 pro
                        SU 2015 pro
                        Firfox
                        This is a must have script and thanks thanks thanks.
                        A fix would sure be appreciated
                        Dave
                          Anton_S
                          I removed the pick and drag feature, just cause I thought upper-right corner of the view was the best location for the dialog. I might re-add it in the next release.
                          It looks like my plugin tries create a new dialog, but in fact, that's the same dialog with border and caption removed. I will make it do such procedure faster, so it's done before the dialog is set visible.
                            dtrarch
                            Anton
                            The pick-and-drag gang will beg
                            dtr
                              dtrarch
                              Hi Anton
                              The border and caption (SU)will be needed to drag the plugin.
                              Also to locate the plugin on another screen.
                              Dave
                                Anton_S
                                @dtrarch said:
                                Hi Anton
                                Dave
                                I won't add the border and caption, cause I think the widows frame doesn't look so good, but I will make the green heading draggable and clippable...
                                  dtrarch
                                  Hi Anton
                                  Good news to be able to drag.
                                  Will it lock to other SU captions ?
                                  Very handy to set a typ screen org for templates.
                                  Here is how I use them in any case.
                                  (in line here)
                                  SU Window Settings is on screen #2
                                  Your plugin should have been part of SU from the very beginning.
                                  Thanks for getting back too.
                                  Dave
                                    Anton_S
                                    4.1.0 has been released!
                                    • Added pick, drag and clip feature to the new dialog.
                                    • Made borders hide faster.
                                    • Added localization to dialog.
                                    Click on green caption to drag the dialog, easy as that...
                                      dtrarch
                                      Anton
                                      V4.1.0 did not drag (or move) green title and would not close menu when arrow was clicked.
                                      SU title hide was still slow.
                                      Show/Hide toolbars and dialogs killed all my on screen settings for both when invoked.
                                      Sorry
                                      Dave
                                        Anton_S
                                        @dtrarch said:
                                        Anton
                                        Sorry
                                        Dave
                                        It works well on my windows 7. What operating system are you using and what internet explorer version?
                                        Edit: I tested on my Windows XP (with IE9) and it doesn't work just like you described. There is not much I can do about compatibility other than retrieving the original version. So, if you use IE9, use the old version which is compatible in SU2014 and below. You need AMS Library 1.0.9 for the old version too. Here are the links:
                                        ams_lib_1.0.9.zip
                                        ams_WindowSetttings_3.8.1.zip
                                          dtrarch
                                          Hi Anton
                                          I have Win 7 pro
                                          SU 2015 pro
                                          (this is the problem SU version)
                                          (Not much else installed)
                                          Tig extrude lines.rb
                                          Wiki tools
                                          Works fine on SU 2014 Pro
                                          Firefox browser most updated
                                          Win Explorer 11 installed
                                          Dave
                                            Anton_S
                                            Ok, I will look into it
                                            • 14
                                            • 15
                                            • 8 / 15
