    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 428.0k Views 80 Watching
      Anton_S
      @archiea said:
      Thank you. I got it working on SU 2014 on Windows 8. Easy enough when it's clear. I've started using it using F12 to toggle. Great plugin!
      Very well, I'll add the description to first post. ๐Ÿ˜„
      @chri said:
      Is-it difficult to create a file ( rb for example ) to change the commands language ?
      Yeah, its quite difficult to translate webdialogs.
      I heard Aerilius created a method, that could translate the Webdialog, so we'll see.
      Thanks for request.
      • JQLJ Offline
        JQL
        Hi Anton,
        I don't think this plugin is 2015 ready or is it?
        www.casca.pt
        Visit us on facebook!
          Pherim
          It's not, because AMS library isn't.
          • CadFatherC Offline
            CadFather
            Thank you Master Anton!
            (can't believe i was even few weeks without WS!)
            laptop is smiling again. ๐Ÿ˜„ ๐Ÿ˜Ž
              @max
              That laptop is unique.
              Treasure it
                CadFather
                true... ๐Ÿ˜† and you should see it now!
                PS. easy with your psychic powers.... (i sold it today) ๐Ÿ˜ฎ
                  They say there's one born every minute.
                    CadFather
                    hahaha... not at all mister, this is a beast which should last plenty (unless you jinx it!) ๐Ÿ˜†
                      CadFather
                      only strange thing i found, the green settings window always pops up on start, even if i uncheck the option. not sure it's supposed to be that way.
                        Anton_S
                        It shouldn't show up if you uncheck the "Show on Start" option. I tested it on my Windows 7, SU8, 13, 14, and 15 64bit. Can you give give me your system background, such as OS and SU version?
                          CadFather
                          ok, so that's strange, it happens on all my versions (8, 2014, 2015-x64).
                          i guess you may want to wait if anyone else has the same problem while i investigate further for conflicts etc. win7 64bit.
                          Thanks Anton
                            Anton_S
                            Thanks Anton
                            Hmm...
                            I think swo_on_quit observer from the new AMS library doesn't work properly. I will look into it. Just to ensure that other observers work, I would like you to do a simple test:
                            1. Open Window Settings dialog, and use the menu bar option (Menu)Window > Settings > Full Screen to switch SU full screen. See if the dialog updates its radio-button mode.
                            2. Another test, maximize and restore your SketchUp window using the maximize button on the upper right corner of the window. See if the dialog updates its radio-button mode.
                            If the dialog doesn't updates, then there is a problem with the whole observing system in my new library; otherwise, it's just this swo_on_quit observer not working for some...
                            I would appreciate your tests,
                              CadFather
                              ok, on all tests the radio buttons update properly. this with 2015x64
                                Anton_S
                                Phew! It's just the swo_on_quit observer method that doesn't work on all systems. I will investigate.
                                  CadFather
                                  phew! ๐Ÿ˜†
                                    Anton_S
                                    I think I know why it isn't working. Basically, when you close the dialog, by default the dialog unregisters the observer, which prevents the swo_on_quit observer method from being triggered. But, just to ensure the swo_on_quit is working, paste and submit this code into ruby console and quit SketchUp. This should show the 'Works!' message box.
                                    class AMSObserverTest; def swo_on_quit; UI.messagebox('Works!'); end; end; AMS;;Sketchup.add_observer(AMSObserverTest.new)
                                      CadFather
                                      exactly as you described it - i got a 'works!' button as i quit SU.
                                      (on reopening i still got the green bar)
                                        Anton_S
                                        Ghurait! Try the new version!
                                        (The test you did was meant to check AMS Library observer, which had nothing to do with changing how AMS Window Settings 4.0.0 worked.)
                                          CadFather
                                          yeeeeaaa! fantastic Master Anton, works ghurait now! ๐Ÿ˜„ ๐Ÿ‘
                                            dtrarch
                                            ams window dialog stuck.jpgHi Anton
                                            The settings dialog icon from your plugin tries to open the SU program dialog for an instant but closes and just opens your settings.
                                            No way to move to another monitor or make floating.
                                            just a fixed location per my screen clip.
                                            (Your settings is grayed out by screen capture software)
                                            Win 7 pro
                                            SU 2015 pro
                                            Firfox
                                            This is a must have script and thanks thanks thanks.
                                            A fix would sure be appreciated
                                            Dave
                                            • 14
                                            • 15
                                            • 8 / 15
