    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 451.4k Views 80 Watching
      Anton_S
      @archieA The plugins folder is located in %appdata%\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
      This plugin is not a standalone plugin. It requires AMS Library. Here is the link: http://sketchucation.com/forums/viewtopic.php?t=55067#p499835 Extract AMS Library in the plugins folder as well.
      • ArchieAA Offline
        ArchieA
        Thank you. I got it working on SU 2014 on Windows 8. Easy enough when it's clear. I've started using it using F12 to toggle. Great plugin!
        • chriC Offline
          chri
          Hi Anton
          You have done a great job ๐Ÿ‘
          Is-it difficult to create a file ( rb for example ) to change the commands language ?
          I have done a french example of what i mean on the next pictures .
          Bye
          Chri
            Anton_S
            Very well, I'll add the description to first post. ๐Ÿ˜„
            Yeah, its quite difficult to translate webdialogs.
            I heard Aerilius created a method, that could translate the Webdialog, so we'll see.
            Thanks for request.
            • JQLJ Offline
              JQL
              Hi Anton,
              I don't think this plugin is 2015 ready or is it?
              www.casca.pt
              Visit us on facebook!
                Pherim
                It's not, because AMS library isn't.
                • CadFatherC Offline
                  CadFather
                  Thank you Master Anton!
                  (can't believe i was even few weeks without WS!)
                  laptop is smiling again. ๐Ÿ˜„ ๐Ÿ˜Ž
                    @max
                    That laptop is unique.
                    Treasure it
                      CadFather
                      true... ๐Ÿ˜† and you should see it now!
                      PS. easy with your psychic powers.... (i sold it today) ๐Ÿ˜ฎ
                        They say there's one born every minute.
                          CadFather
                          hahaha... not at all mister, this is a beast which should last plenty (unless you jinx it!) ๐Ÿ˜†
                            CadFather
                            only strange thing i found, the green settings window always pops up on start, even if i uncheck the option. not sure it's supposed to be that way.
                              Anton_S
                              It shouldn't show up if you uncheck the "Show on Start" option. I tested it on my Windows 7, SU8, 13, 14, and 15 64bit. Can you give give me your system background, such as OS and SU version?
                                CadFather
                                ok, so that's strange, it happens on all my versions (8, 2014, 2015-x64).
                                i guess you may want to wait if anyone else has the same problem while i investigate further for conflicts etc. win7 64bit.
                                Thanks Anton
                                  Anton_S
                                  Thanks Anton
                                  Hmm...
                                  I think swo_on_quit observer from the new AMS library doesn't work properly. I will look into it. Just to ensure that other observers work, I would like you to do a simple test:
                                  1. Open Window Settings dialog, and use the menu bar option (Menu)Window > Settings > Full Screen to switch SU full screen. See if the dialog updates its radio-button mode.
                                  2. Another test, maximize and restore your SketchUp window using the maximize button on the upper right corner of the window. See if the dialog updates its radio-button mode.
                                  If the dialog doesn't updates, then there is a problem with the whole observing system in my new library; otherwise, it's just this swo_on_quit observer not working for some...
                                  I would appreciate your tests,
                                    CadFather
                                    ok, on all tests the radio buttons update properly. this with 2015x64
                                      Anton_S
                                      Phew! It's just the swo_on_quit observer method that doesn't work on all systems. I will investigate.
                                        CadFather
                                        phew! ๐Ÿ˜†
                                          Anton_S
                                          I think I know why it isn't working. Basically, when you close the dialog, by default the dialog unregisters the observer, which prevents the swo_on_quit observer method from being triggered. But, just to ensure the swo_on_quit is working, paste and submit this code into ruby console and quit SketchUp. This should show the 'Works!' message box.
                                          class AMSObserverTest; def swo_on_quit; UI.messagebox('Works!'); end; end; AMS;;Sketchup.add_observer(AMSObserverTest.new)
                                            CadFather
                                            exactly as you described it - i got a 'works!' button as i quit SU.
                                            (on reopening i still got the green bar)
                                            • 14
                                            • 15
                                            • 8 / 15
