    Joining a circle and square: how to
    20 Posts 7 Posters 1.2k Views 7 Watching
    • EdsonE
      Edson
      I am no newbie but since this is a typical newbie question I am posting it here.
      what I want to do is joining a circle and a square. what plugin would do it?
      http://www.mahfuz.arq.br
      • BoxB
        Curviloft for one.
        • gillesG
          gilles
          Move tool can do it ,but not very accurate.
          Curviloft is better.
          The line tool is ok too
          Move tool+cmd (on Mac)
          • charly2008C
            charly2008
            Ferrari can do it too
            • EdsonE
              Edson
              thanks, guys. curviloft did the trick. I tried with the move tool but it did not work well as the circle had only 12 segments.
              charly, I have never heard of the ferrari plugin! 😮 where can I find it?
              • charly2008C
                charly2008
                Hi Edson,
                have a look at this Thread
                404 Not Found
                (forums.sketchucation.com)
                Charly
                • Jean LemireJ
                  Jean Lemire
                  Hi Edson, hi folks.
                  Maybe you want to do it with native tools (always a good way to learn, especially for newbies).
                  See this SU file for ideas.
                  Square to round transition.skp
                  • EdsonE
                    Edson
                    hi jean,
                    I am having trouble opening your file: it goes on forever generating scene thumbnails. could you possibly disable the scene generating feature, save it and post it again?
                    • irwanwrI
                      irwanwr
                      it opened and works fine for me
                      • Jean LemireJ
                        Jean Lemire
                        Hi Edson, hi folks.
                        My file is a very simple normal skpfile with 8 scenes.
                        Maybe you have a plugin that is causing trouble.
                        Just ideas
                        • EdsonE
                          Edson
                          in one of those weird coincidences that would make Jung happy Aidan Chopra has just posted an article on Curviloft at the Official Google Sketchup Blog and the first example is exactly the question I posted here.
                          • EdsonE
                            Edson
                            @jean lemire said:
                            Hi Edson, hi folks.
                            Just ideas
                            jean,
                            I disabled all plugins but the problem remained the same. thanks anyway.
                            • gillesG
                              gilles
                              This file is ok, 98 KB.
                              Have you try to re-download?
                              • EdsonE
                                Edson
                                yes, I have. it is very odd because it is the only file that I am having problems with.
                                • BoxB
                                  Try this one, I save it as SU 7
                                  Square to round transition SK7.skp
                                  • EdsonE
                                    Edson
                                    same problem: it goes on forever generating scene thumbnails. could you possibly disable this feature and save it again? to do that just go to the scenes dialogue box, select all scenes, right-click and uncheck Use Sene Thumbnails. thanks.
                                    • BoxB
                                      Here you go
                                      Square to round transition No Thumbs.skp
                                      • EdsonE
                                        Edson
                                        @box said:
                                        Here you go
                                        IT WORKED! thanks, ben. and thanks to jean for the tutorial. 👍
                                        • BoxB
                                          Glad it worked, but there must be something odd with your system if it can't handle the thumbnails.
                                          Perhaps Tig or another of the intellectual giants here can solve it for you.
                                          • TIGT
                                            Unfortunately there seems to be no API access to 'StyleOptions' 😞
