    Joining a circle and square: how to
    20 Posts 7 Posters 1.2k Views 7 Watching
    • charly2008C
      charly2008
      Ferrari can do it too
      • EdsonE
        Edson
        thanks, guys. curviloft did the trick. I tried with the move tool but it did not work well as the circle had only 12 segments.
        charly, I have never heard of the ferrari plugin! 😮 where can I find it?
        http://www.mahfuz.arq.br
        • charly2008C
          charly2008
          Hi Edson,
          have a look at this Thread
          404 Not Found
          (forums.sketchucation.com)
          Charly
          • Jean LemireJ
            Jean Lemire
            Hi Edson, hi folks.
            Maybe you want to do it with native tools (always a good way to learn, especially for newbies).
            See this SU file for ideas.
            Square to round transition.skp
            • EdsonE
              Edson
              hi jean,
              I am having trouble opening your file: it goes on forever generating scene thumbnails. could you possibly disable the scene generating feature, save it and post it again?
              • irwanwrI
                irwanwr
                it opened and works fine for me
                • Jean LemireJ
                  Jean Lemire
                  Hi Edson, hi folks.
                  My file is a very simple normal skpfile with 8 scenes.
                  Maybe you have a plugin that is causing trouble.
                  Just ideas
                  • EdsonE
                    Edson
                    in one of those weird coincidences that would make Jung happy Aidan Chopra has just posted an article on Curviloft at the Official Google Sketchup Blog and the first example is exactly the question I posted here.
                    • EdsonE
                      Edson
                      @jean lemire said:
                      Hi Edson, hi folks.
                      Just ideas
                      jean,
                      I disabled all plugins but the problem remained the same. thanks anyway.
                      • gillesG
                        gilles
                        This file is ok, 98 KB.
                        Have you try to re-download?
                        • EdsonE
                          Edson
                          yes, I have. it is very odd because it is the only file that I am having problems with.
                          • BoxB
                            Try this one, I save it as SU 7
                            Square to round transition SK7.skp
                            • EdsonE
                              Edson
                              same problem: it goes on forever generating scene thumbnails. could you possibly disable this feature and save it again? to do that just go to the scenes dialogue box, select all scenes, right-click and uncheck Use Sene Thumbnails. thanks.
                              • BoxB
                                Here you go
                                Square to round transition No Thumbs.skp
                                • EdsonE
                                  Edson
                                  @box said:
                                  Here you go
                                  IT WORKED! thanks, ben. and thanks to jean for the tutorial. 👍
                                  • BoxB
                                    Glad it worked, but there must be something odd with your system if it can't handle the thumbnails.
                                    Perhaps Tig or another of the intellectual giants here can solve it for you.
                                      Unfortunately there seems to be no API access to 'StyleOptions' 😞
