    Making tyres in SU
    65 Posts 11 Posters 4.0k Views 11 Watching
    • simon le bonS Offline
      simon le bon
      Hi misters,
      This is definitely an instructive thread with many important tip and tricks 👍 👍
      @gaieus said:
      I used UV Tools (not UV Toolit)
      Whaat_UVTools v0.1
      Whaat_UVTools 0.2 Pro (Beta)
      Whaat_UVTool tutorial
      @gaieus said:
      Good. What are you rendering it with? It looks like Kerkythea. IMO a little (bit more enhanced?) bumpiness would add to it. Of course, eventually there needs to be some environment or a render to look good (even for the reflections as there needs to be something reflected of course)
      http://forums.sketchucation.com/viewtopic.php?f=79&t=42691&start=15#p380035
      Concerning giving some bump in a render engine:
      Here are some useful links:
      [url=http://news.sketchucation.com/making-bumpmaps-in-google-sketchup/:33lcwfn0]Making Bumpmaps in Google SketchUp[/url:33lcwfn0]
      http://news.sketchucation.com/files/2010/09/Making-Bump-Maps-in-Google-SketchUp.jpg
      to understand better this technic:
      [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=16660&start=15#p131738:33lcwfn0]Re: [Plugin] Color by Z[/url:33lcwfn0]
      [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=24513&start=30#p243505:33lcwfn0]Re: [Plugin] Heightmap from model[/url:33lcwfn0]
      and to obtain the modeled texture into SketchUp you can use
      Thomthom's Bitmap to Mesh: see the video and download link in Rich's famous [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=39504:33lcwfn0]SketchUcation Plugin Video Tutorials[/url:33lcwfn0]
      [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=33183#p292727:33lcwfn0][Plugin] Normal Map Maker[/url:33lcwfn0]
      and I've just discovered this tutorial to give some bump into Photoshop:
      Bump maps in Photoshop
      [url:33lcwfn0]http://www.michaeldashow.com/tips_bumpmaps.html[/url:33lcwfn0]
      Cheers,
      simon
        lecra
        @Gaieus,
        Thank you very much for your answer. I will give UV Tools a try and learn another plug-in 😞 One more and my head will explode next
        BTW, this is a new view of tires Gaieus. I think the tire industry would not be amused if customer wants to have new tires with an horizontal tread 🤣 I know, this is only for demonstration purpose but it looks very strange if the tread is 90° rotated....
        Thank you again.
        KR; Lecra
        I'm new to SU but so thirstily to learn all the stuff. Help me fighting against my thirst
        • gillesG Offline
          gilles
          I have looked at your model, have you any reason to give your tire thickness?
            lecra
            Hi Simon,
            @simon le bon said:
            Hi misters,
            I agree with you, definitely, this is a very important thread for me too. As a SU newbie there are a lot of behaviors not known or not understood in SU but for the 'hot shots' completely self-evident. This is maybe the reason why this thread is such long. Many times the professionals (you all) are giving excellent hints but we newbies are missing a guide how to reach the goal. If you miss to do one step the result can be completely different... This is very important for the professionals to think that they were also starting from the scratch and they have reached their level in trying, asking, watching video tutorials and learning investing tons of hours.
            Thomthom's Bitmap to Mesh: see the video and download link in Rich's famous SketchUcation Plugin Video Tutorials
            Simon, I would like to thank you very much for the additional links and information's. This is very useful for me and for sure also for other people.
            KR; Lecra
              lecra
              Hi Gilles,
              Which thickness do you mean? Strength of materials or the width of the tire? Strength of materials was given due to the drawn profile that I have revolved with the follow-me tool. Width of the tire is given by the function of this tire. This is an implement tire used in the farming industry which will be flatten with the weight of the charge (2-3 tons).
              KR; Lecra
                @lecra said:
                ...BTW, this is a new view of tires Gaieus. I think the tire industry would not be amused if customer wants to have new tires with an horizontal tread 🤣 I know, this is only for demonstration purpose but it looks very strange if the tread is 90° rotated...
                Haha. I did not even realize. I saw something was wrong but just went ahead with the example. 😄
                • gillesG Offline
                  gilles
                  I mean this, it will increase the size of the file.
                    Ah yes, I also noticed that the tyre has wall thickness. Completely unnecessary. In theory, indeed it is advisable to model everything "physically correct" (i.e. with thickness) but only where really needed.
                      lecra
                      Gilles,
                      No specific reason 😲 It comes out of the idea to incorporate the tread in the profile and then revolve. This will produce a lot of additional faces which are not desired in the game engine I use, using a lot of memory. Below you can see the very beginning of the model:
                      A bientôt.
                      KR; Lecra
                      • gillesG Offline
                        gilles
                        You could do it this way.
                        Less work.
                          lecra
                          Gilles,
                          Less work.
                          I know. I take this way out of another idea.
                          The problem is still the UV mapping of the tread and sidewall. I had a look at the UV Tools Gaieus mentioned, but I really don't know how to use that. It is so complicated!!
                          KR; Lecra
                          • gillesG Offline
                            gilles
                            http://forums.sketchucation.com/viewtopic.php?t=39442#p348501
                              lecra
                              Dear Gilles,
                              Thank you for your short tutorial. I will give it a tray, even if QuadFace is still a 'black book' for me! 😮 😉
                              KR; Lecra
                              • oganocaliO Offline
                                oganocali
                                You may want to check out Tgi3D's cross-section-editing tool. This feature is unlimited in the free training edition.
                                Ogan
                                  lecra
                                  Hi oganocali,
                                  Ogan
                                  Where do you mean can I use this plugin? Concerning what? Can this help me fighting against the texture mapping issues I have?
                                  KR; Lecra
                                    oganocali
                                    Basically you use it to convert the cylinder on the right to the tire on the left (with texture) easily.
                                      lecra
                                      Hi oganocali,
                                      [attachment=0:3vfaxnzg]<!-- ia0 -->crossexample.jpg<!-- ia0 -->[/attachment:3vfaxnzg]
                                      Ohh, I see. Interesting. I was searching for this tool, but I'm not sure if I understood that this is part of the Amorph plug-in, right?
                                      Thank you for your support.
                                      KR; Lecra
                                        oganocali
                                        Yes this is part of Tgi3D Amorph. This feature is available unlimited for free in the training version.
                                          lecra
                                          Hi all,
                                          Me again! I hope to nott bother you with my problems but this story with the tires is really producing headache to me. In this tread i received a lot of suggestions how to make such a tire. I choose the one with thomthom Quadface tool. This one is leading me to something that I also don't understand:
                                          How can I have this space on the left and right side at the edge and not having the canal near to the sidewall edge? I have deleted the canal left and right in the texture but this does not help.
                                          Attached the model:
                                          FlotationTireStrautmann6.skp
                                          KR; Lecra
                                            lecra
                                            oganocali,
                                            [attachment=0:96mqqya7]<!-- ia0 -->crossexample.jpg<!-- ia0 -->[/attachment:96mqqya7]
                                            Could you show me how you have formed the cylinder with TIG cross section tools?
                                            KR; Lecra
                                            • 3 / 4
