    Making tyres in SU
    65 Posts 11 Posters 6.0k Views 11 Watching
    • gillesG Offline
      gilles
      You could do it this way.
      Less work.
        lecra
        Gilles,
        Less work.
        I know. I take this way out of another idea.
        The problem is still the UV mapping of the tread and sidewall. I had a look at the UV Tools Gaieus mentioned, but I really don't know how to use that. It is so complicated!!
        KR; Lecra
        I'm new to SU but so thirstily to learn all the stuff. Help me fighting against my thirst
        • gillesG Offline
          gilles
          http://forums.sketchucation.com/viewtopic.php?t=39442#p348501
            lecra
            Dear Gilles,
            Thank you for your short tutorial. I will give it a tray, even if QuadFace is still a 'black book' for me! 😮 😉
            KR; Lecra
            • oganocaliO Offline
              oganocali
              You may want to check out Tgi3D's cross-section-editing tool. This feature is unlimited in the free training edition.
              Ogan
                lecra
                Hi oganocali,
                Ogan
                Where do you mean can I use this plugin? Concerning what? Can this help me fighting against the texture mapping issues I have?
                KR; Lecra
                  oganocali
                  Basically you use it to convert the cylinder on the right to the tire on the left (with texture) easily.
                    lecra
                    Hi oganocali,
                    [attachment=0:3vfaxnzg]<!-- ia0 -->crossexample.jpg<!-- ia0 -->[/attachment:3vfaxnzg]
                    Ohh, I see. Interesting. I was searching for this tool, but I'm not sure if I understood that this is part of the Amorph plug-in, right?
                    Thank you for your support.
                    KR; Lecra
                      oganocali
                      Yes this is part of Tgi3D Amorph. This feature is available unlimited for free in the training version.
                        lecra
                        Hi all,
                        Me again! I hope to nott bother you with my problems but this story with the tires is really producing headache to me. In this tread i received a lot of suggestions how to make such a tire. I choose the one with thomthom Quadface tool. This one is leading me to something that I also don't understand:
                        How can I have this space on the left and right side at the edge and not having the canal near to the sidewall edge? I have deleted the canal left and right in the texture but this does not help.
                        Attached the model:
                        FlotationTireStrautmann6.skp
                        KR; Lecra
                          lecra
                          oganocali,
                          [attachment=0:96mqqya7]<!-- ia0 -->crossexample.jpg<!-- ia0 -->[/attachment:96mqqya7]
                          Could you show me how you have formed the cylinder with TIG cross section tools?
                          KR; Lecra
                            oganocali
                            Here is a video explaining the usage of Tgi3D cross section editing tool. In your case you should texture the cylinder before you edit it into the tire shape.
                            [flash=800,620:x8ykvevl]http://www.youtube.com/v/11mhfNJlduE?fs=1&hl=en_US[/flash:x8ykvevl]
                              lecra
                              Hi oganocali,
                              I have downloaded the training version, installed but I have just only this toolbar available and there is no cross section tool available! What I'm doing wrong??
                              KR; Lecra
                                oganocali
                                Opps the video showed old icons. 😳
                                The 4th tool from the left is the cross section tool. In SU most tools provide a hint if you hover the cursor over the icon a few seconds.
                                • H Offline
                                  Hussel Hann
                                  attempt to model the tyre..its a tedious job. 😳
                                  if only there is a plugin that able to wrap something to a curve surface...or maybe it do exist but i've missed it.
                                  • H Offline
                                    Hussel Hann
                                    rendered with KT.
                                    trying so hard to get the effect as per the real thing but to no avail... 😢
                                    • 3 / 4
