    Making tyres in SU
    65 Posts 11 Posters 5.8k Views 11 Watching
      lecra
      Alan,
      @alan fraser said:
      You'd need to use some other more sophisticated mapping software, like Ultimate Unwrap 3D, or perhaps try Thomthom's Quadface Tools plugin.
      Thank you for your answer. I had a look to Quadface Tools but as a newbee it is not so easy to apply these tools. I had a look to the movies from thomthom but it sounds for me very strong.
      KR; Lecra
      I'm new to SU but so thirstily to learn all the stuff. Help me fighting against my thirst
      • soloS Offline
        I create a section, then copy rotate, see images.
          lecra
          solo,
          Thank you for your answer. I got it, but I imagine that you have textured the section in the same way as Alan proposed in this thread, right?
          KR; Lecra
            I used UV Tools (not UV Toolit) > cylindrical projection on the middle part and simply projected the sides (I had to scale the sides up by 1.01% as there was a white halo around).
            FlotationTire.skp
            I also used Twilight above (technically speaking, it will result very similar renders as Kerkythea since it uses its engine).
            • simon le bonS Offline
              simon le bon
              Hi misters,
              This is definitely an instructive thread with many important tip and tricks 👍 👍
              Whaat_UVTools v0.1
              Whaat_UVTools 0.2 Pro (Beta)
              Whaat_UVTool tutorial
              @gaieus said:
              Good. What are you rendering it with? It looks like Kerkythea. IMO a little (bit more enhanced?) bumpiness would add to it. Of course, eventually there needs to be some environment or a render to look good (even for the reflections as there needs to be something reflected of course)
              http://forums.sketchucation.com/viewtopic.php?f=79&t=42691&start=15#p380035
              Concerning giving some bump in a render engine:
              Here are some useful links:
              [url=http://news.sketchucation.com/making-bumpmaps-in-google-sketchup/:33lcwfn0]Making Bumpmaps in Google SketchUp[/url:33lcwfn0]
              http://news.sketchucation.com/files/2010/09/Making-Bump-Maps-in-Google-SketchUp.jpg
              to understand better this technic:
              [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=16660&start=15#p131738:33lcwfn0]Re: [Plugin] Color by Z[/url:33lcwfn0]
              [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=24513&start=30#p243505:33lcwfn0]Re: [Plugin] Heightmap from model[/url:33lcwfn0]
              and to obtain the modeled texture into SketchUp you can use
              Thomthom's Bitmap to Mesh: see the video and download link in Rich's famous [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=39504:33lcwfn0]SketchUcation Plugin Video Tutorials[/url:33lcwfn0]
              [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=33183#p292727:33lcwfn0][Plugin] Normal Map Maker[/url:33lcwfn0]
              and I've just discovered this tutorial to give some bump into Photoshop:
              Bump maps in Photoshop
              [url:33lcwfn0]http://www.michaeldashow.com/tips_bumpmaps.html[/url:33lcwfn0]
              Cheers,
              simon
                lecra
                @Gaieus,
                Thank you very much for your answer. I will give UV Tools a try and learn another plug-in 😞 One more and my head will explode next
                BTW, this is a new view of tires Gaieus. I think the tire industry would not be amused if customer wants to have new tires with an horizontal tread 🤣 I know, this is only for demonstration purpose but it looks very strange if the tread is 90° rotated....
                Thank you again.
                KR; Lecra
                • gillesG Offline
                  gilles
                  I have looked at your model, have you any reason to give your tire thickness?
                    lecra
                    Hi Simon,
                    @simon le bon said:
                    Hi misters,
                    I agree with you, definitely, this is a very important thread for me too. As a SU newbie there are a lot of behaviors not known or not understood in SU but for the 'hot shots' completely self-evident. This is maybe the reason why this thread is such long. Many times the professionals (you all) are giving excellent hints but we newbies are missing a guide how to reach the goal. If you miss to do one step the result can be completely different... This is very important for the professionals to think that they were also starting from the scratch and they have reached their level in trying, asking, watching video tutorials and learning investing tons of hours.
                    Thomthom's Bitmap to Mesh: see the video and download link in Rich's famous SketchUcation Plugin Video Tutorials
                    Simon, I would like to thank you very much for the additional links and information's. This is very useful for me and for sure also for other people.
                    KR; Lecra
                      lecra
                      Hi Gilles,
                      Which thickness do you mean? Strength of materials or the width of the tire? Strength of materials was given due to the drawn profile that I have revolved with the follow-me tool. Width of the tire is given by the function of this tire. This is an implement tire used in the farming industry which will be flatten with the weight of the charge (2-3 tons).
                      KR; Lecra
                        @lecra said:
                        ...BTW, this is a new view of tires Gaieus. I think the tire industry would not be amused if customer wants to have new tires with an horizontal tread 🤣 I know, this is only for demonstration purpose but it looks very strange if the tread is 90° rotated...
                        Haha. I did not even realize. I saw something was wrong but just went ahead with the example. 😄
                        • gillesG Offline
                          gilles
                          I mean this, it will increase the size of the file.
                            Ah yes, I also noticed that the tyre has wall thickness. Completely unnecessary. In theory, indeed it is advisable to model everything "physically correct" (i.e. with thickness) but only where really needed.
                              lecra
                              Gilles,
                              No specific reason 😲 It comes out of the idea to incorporate the tread in the profile and then revolve. This will produce a lot of additional faces which are not desired in the game engine I use, using a lot of memory. Below you can see the very beginning of the model:
                              A bientôt.
                              KR; Lecra
                              • gillesG Offline
                                gilles
                                You could do it this way.
                                Less work.
                                  lecra
                                  Gilles,
                                  Less work.
                                  I know. I take this way out of another idea.
                                  The problem is still the UV mapping of the tread and sidewall. I had a look at the UV Tools Gaieus mentioned, but I really don't know how to use that. It is so complicated!!
                                  KR; Lecra
                                  • gillesG Offline
                                    gilles
                                    http://forums.sketchucation.com/viewtopic.php?t=39442#p348501
                                      lecra
                                      Dear Gilles,
                                      Thank you for your short tutorial. I will give it a tray, even if QuadFace is still a 'black book' for me! 😮 😉
                                      KR; Lecra
                                      • oganocaliO Offline
                                        oganocali
                                        You may want to check out Tgi3D's cross-section-editing tool. This feature is unlimited in the free training edition.
                                        Ogan
                                          lecra
                                          Hi oganocali,
                                          Ogan
                                          Where do you mean can I use this plugin? Concerning what? Can this help me fighting against the texture mapping issues I have?
                                          KR; Lecra
                                            oganocali
                                            Basically you use it to convert the cylinder on the right to the tire on the left (with texture) easily.
                                            • 3 / 4
